Question about Whirlpool GB2SHDXTS Stainless Steel
Hi. I have a Whirlpool GB2SHDXTS01 refrigerator with an ice maker. Problem: The ice is coming out as a shell, not solid. The owners manual makes it sound like I may have a water filter on the unit and says it is in the refrigerator part up high on the right hand side of the cabinet. There isn't anything on the upper right hand side of the top cabinet. Maybe it doesn't even have a filter, I can't tell. Any ideas?
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
  • 531 Answers
SOURCE: drip pan is overflowing, ice maker works, no water
is not the filter water line frozen in refrigerator or water valve check and see if refrigerator door (ajar)
Posted on Apr 07, 2009
  • 173 Answers
SOURCE: Ice maker does not make solid ice anymore.
Clean cooling coils. Check refrigerant level.
Posted on Jul 08, 2009
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Ice maker does not work
magic chef mini fridge stops colding
mod#MCBR171W 1.7cu ft
Jun 30, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Ice that comes out maker is not solid, just the out shell of ice cube.
clean coils at back and under fridge, and make sure fans are running ...also check defrost cycle is working
Aug 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Mar 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Open Questions:
Whirlpool GB2SHDXTS Stainless Steel Logo
188 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
