Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio washer problems
I have had my Whirlpool Cabrio for 3+ years. For the last 6 months it stops at 12/13 minutes and does not finish the wash. It just stays on that phase... or after a length of time shuts off and flashes "UL". The only way I can finish this load is to cut the power, let it drain, and then "rinse and spin". Sometimes that doesn't ever work and I have to go to "drain and spin". One load of clothes can take hours. This is not good.
I am so disappointed in this washer. I thought I was buying the best. Does Whrilpool build in a 3 year obsolescence?
I only do about 4 loads of laundry a week, so it is definitely not overused. But ... I would expect it to be able to be overused!
Is there something I can do to fix this without a costly repair?
Martha
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
  • 1314 Answers
SOURCE: UL Code
if you have cleared the codes by pressing pause/cancel and the codes keep setting call for service your still under warrenty let them deal with it
Posted on Jan 12, 2008
SOURCE: Whirlpool Duet Washer Leaking
Thanks Master Tech! I removed the lint clean out and found some chewed up change. I cleaned it, put it back and ran a load. It usually fills up overnight. So far it looks good!
Posted on Feb 15, 2008
SOURCE: moldy smelling clothes
I found that as soon as I stopped using the liquid detergent there was no smell. I have been using powderdetergant ( costco he ) and vinager in the rinse. Also leave door open, but did that before. I have cleaned the machine with bleach and vinager on the rinse cycle. the comment about washing a washing machine; I did this with my top loader also.
Posted on Aug 06, 2008
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
Hello;
My name is Peter. I am a retired field service appliance technician.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
Dec 08, 2014 | Washing Machines
When we try to wash a load of laundry after a couple minutes we get the code F1 show up and the wash cycle turns off. What is F1 and how can we fix it so the Whirlpool Cabrio washer will work again?
We have had the same problem for three years. We are only using this washer about 4 months a year. We has two service calls..no help. We had to baby sit the washer just like all the other posts, pressing pause about five or six times or more.
Well, I read the posts & that Whirlpool had fixed this problem, paying for parts & labor..we called..they sent a repairman. It took him 20 minutes, he asked if this was the code, said he carried at least three of these parts & now..the washer has been running fine. three loads so far.
So, call them, tell them the problem & it will be fixed at no expense to you..or should be.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool cabrio washer that displays LF when I try to start a wash load. The water comes into the tub but it doesn't fill. After some time, maybe 10 minutes, the washer stops and displays LF....
Aha the old LF : Captain we have a problem. What is it Spock? Computers cannot confirm water is filling, water level does not change. Spock you did pay the water bill this month? What could it be Spock? Captain the inlet screens appear to have contaminants. Suggest you jettison them. If that does not solve it see test #2b7fe528.jpg
May 15, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Same F1 Fault Code
The only action you can take is to raise your voice with other people who have faced a same issue with Whirlpool :-
http://www.petitiononline.com/cabrio08/petition.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
158 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
