Question about Frigidaire AGQ6000ES Gas Dryer
The dryer stops after about 15+ seconds.
The drum turns and sometimes you can hear the burner ignite but within another 10 seconds the drum stops turning and the three lights on the right upper corner of the dryer (drying, cool down and extended tumble lights) all start flashing. The other lights on the panel stay lit along with the timer. Pressing the "cancel" button turns the flashing lights off. It has done this before but seemed to cure itself after choosing a different drying cycle. It now turns off no matter what cycle you put it in. The instructions that came with the dryer only talk about the "dryers runs but won't heat" and mentions "2 house fuses in the dryer circuit". It says "replace fuse" as the cure but no where in the instructions does it say where in the dryer is the "circuit" or the fuses. Also, if it was a blown fuse, why did the problem go away last time? Also, I don't think this is the same problem since the dryer completely stops running, not just "dryer runs but won't heat".
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
Posted on May 31, 2010
  • legalchili May 31, 2010
    I played around with it and realized the "temp" button was stuck in. I pushed it to "unstick" it and now it works fine!
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
My pt cruiser won't start... Not because of the battery or engine but because of the anti theft... Weve tried all keys and remotes to no avail... What now?
Programming
When
System malfunction. Key added or replaced.
How
NOTE: Two programmed keys necessary. Complete each step within 15 seconds. NOTE: Some models - replacement key can only be programmed using diagnostic equipment.
Obtain all keys to be programmed. Using first programmed key, proceed as follows: Switch ignition ON and OFF within 15 seconds. Using second programmed key, proceed as follows: Switch ignition ON and OFF within 15 seconds. Within 10 seconds: Immobilizer LED flashes. Programming mode activated (acoustic signal will be heard). Proceed as follows: Within 50 seconds: Insert first key to be programmed into ignition switch. Switch ignition ON and OFF. Within 10 seconds: Single acoustic signal will be heard and immobilizer LED stops flashing and illuminates for 3 seconds to indicate correct programming. Repeat complete procedure to program remaining keys. Keys can also be programmed using diagnostic equipment.
Jun 25, 2010 | 2003 Chrysler PT Cruiser
Gas dry will not heat
Do this first
Remove all exhaust vent tubing and clean it out thoroughly.
Any lint build up will prevent the burner to operate
A moister sensor stops the burner when it senses lint build up
Reattach the vents now and proceed to the next steps below
If thoroughly cleaned & no build up is present start the dryer and listen for the spark ignitor to click. If it does not click the ignitor is bad. If it does click and no heat appears to come through the dryers drum within 30 seconds the moister sensor is at fault
May 17, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
It just stopped heating
If you have a gas dryer the burner is ignited by a eletroniic ignitor. It will make a ckicking noise upon starting it when set in the heat mode. You should hear the click or clicking noise it makes within 30 seconds after starting the dryer. If no click is heard, replace the spark ignitor
Mar 30, 2010 | Dryers
Dryer isn't drying anymore
check the ignitor first it should make a clicking noise within 15 seconds upon turning on the dryer. If no clicking sound is hear you have a bad ignitor for your burner to ignite it
Feb 13, 2010 | Dryers
No heat
If you have a gas dryer check the ignition ignitor. When you turn on the dryer you should hear a clicking sound within 15 seconds. That sound is the ignitor clicking to throw a spark to the burner to ignite. If that sound is not hearf the ignitor is at fault
Dryer runs fine but NO heat?
Check the ignitor switch first. When turned on you should hear a snapping sound within 15 seconds to ignite the burner. If not the ignotor is at fault
Jan 24, 2010 | Dryers
2004 jeep cherokee alarm won't disarm
NOTE: A maximum of 8 keys can be programmed.
Dec 29, 2009 | 2004 Jeep Grand Cherokee
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Dryer was running and drum stopped spinning but still runs
The weight of the wet cushion broke the drum belt. A good handyman can do it or, it's not a terribly expensive service call.
May 07, 2009 | Kenmore Dryers
Dryers Logo
358 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
