Question about Kenmore 13719 / 13712 Built-in Dishwasher
My Kenmore 665.1371 Ultra Wash dishwasher is leaving a lot of white residue on the utensils when the wash cycle is completed. I'm not quite sure why this is happening. Am I using too much detergent?
  • tmd820 Jun 01, 2010
    Awesome! Thank you for your help!
    President:
  • 949 Answers
Residue can be from a couple different sources.
The most common is detergent residue. To resolve this leave the dishes dirty before washing, it is good to scrape food off but leave something for the detergent to react with. If the dishes are not that dirty use a small amount detergent in the main wash cup only. Run your hot water at the sink until hot before starting the dishwasher, this will make sure you have the right temperature to dissolve detergents. Lastly be sure to use rinse aid in the rinse aid dispenser, it will only need filled every month or so but check the gauge to make sure you have some in there.
The second thing that can cause residue is hard water. Look below the lower rack, there is a heat element, it is similar to an electric element in an oven. If the element is black or dark colored it you are okay, if it is white and much larger around in the middle than the very ends of it then you have a hard water build up in the machine. Running a cleaner through will help. See below.
The last thing that can cause a residue is residue of food stuck in the pump causing poor wash action, this typically starts with the top rack and moves down so I do not think this is your issue.
It is a good idea to run a cleaner such as: Lemi-Shine, Glisten, Rinse Aid dishwasher cleaner, Finish dishwasher cleaner. through the machine a couple times a year to help reduce build up inside the pump and arms. I would look at doing this regardless of the outcome of this problem.
Let me know if you need more information.
Phil
Posted on May 31, 2010
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Jun 21, 2015 | Viking Dishwashers
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
Kenmore Ultra Wash dishwasher leaves spots on ALL dishes, top and bottom. Changed detergent, same problem.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 24, 2011 | Kenmore Dishwashers
GE TRITON dish washer. Utensils are stained after wash. I tried all that suggested solutions like cleaning with white vinegar, make sure hot water flows before it starts. I donot think we have hard water...
heatman101
Jan 21, 2011 | Maytag Dishwasher
Leaves baked soap scum on utensils
heatman101
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I got a layer of white cloudy film on my dishes after normal wash
Doing a full vinegar cleaning of the diswhasher is a good start, and every 6 months or so if you have hard water.
But, I have proven that using ultra-cheap dishwasher powder will cause this problem too. Recommend after you do the cleaining with white vinegar through a quick cycle with no detergent, you use only a brand name powder (like Cascade or Electrosol) and see if problems persist.
If problems remain, the heating element has probably failed. Once it is replaced, you will see a dramatic improvement. Good Luck!
Mar 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Mar 01, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Open Questions:
Kenmore 13719 / 13712 Built-in Dishwasher Logo
177 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
