Question about Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC
What do you mean by conguret triangle? - Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC
  • Adnan Bhatti
    Adnan Bhatti May 31, 2010
    Congruent triangle? Two sets are congruent if they have the same shape and size, but are in
    different positions (for instance one may be rotated, flipped, or simply placed
    somewhere else).
    Scholar:
  • 162 Answers
Refer to http://library.thinkquest.org/20991/geo/ctri.html
hope that helps!
good luck!
Posted on May 31, 2010
  • 11,800 Answers
2 triangles are congruent when they have the same angles but different lengths.
The triangle has 3 congruent angles. does not have a ruler to measure the lengths of the sides. How can she show that the triangle has three congruent sides?
Three congruent angles means it is an equilateral triangle, so by definition it has 3 congruent sides. Or, by the Sine Rule of triangles
a/sinA = b/sinB = c/sinC
and since A = B = C (given) then a = b = c.
Apr 08, 2016 | Computers & Internet
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
What does the triangle with the arrow round it mean and what does the triangle with the exclamation mark in mean please
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
Oct 13, 2012 | Cars & Trucks
How to get rid of the yellow triangle
The yellow triangle means there is an https error. (https:// means the website is secure, while http:// denotes the connection is not secure). If you right click on the triangle it will give you a breakdown of what is causing the error.
Mar 27, 2012 | Facebook Social Network
What are the different formula in solving the area, height, base of a trapezoid?
o find the area of a triangle, multiply the base by the height, and then divide by 2. The division by 2 comes from the fact that aparallelogram can be divided into 2 triangles. For example, in the diagram to the left, the area of each triangle is equal to one-half the area of the parallelogram.
Since the area of a parallelogram is area_parallelogram_form.gif, the area of a triangle must be one-half the area of a parallelogram. Thus, the formula for the area of a triangle is: area_triangle1.gif or area_triangle2.gif where b.gif is the base, h.gif is the height and · means multiply. tab.gif The base and height of a triangle must be perpendicular to each other. In each of the examples below, the base is a side of the triangle. However, depending on the triangle, the height may or may not be a side of the triangle. For example, in the right triangle in Example 2, the height is a side of the triangle since it is perpendicular to the base. In the triangles in Examples 1 and 3, the lateral sides are not perpendicular to the base, so a dotted line is drawn to represent the height.
May 13, 2011 | Computers & Internet
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
What does the dotted triangle mean?
On most sharp copiers the dotted triangle that points up is Toner and if it has a triangle that points down that is Waste Bottle
May 13, 2010 | Sharp AL-1457 Black and White Copier
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
What does the triangle symbol with small objects in it mean?
It´s the descaling indicator, you need to descale the machine.
Jul 09, 2008 | Schaerer Opal Espresso Machine
Motorola V262 flashing triangle: what's it mean?
This means that the phone is roaming from the home network
Oct 30, 2007 | Motorola Mobility V262
Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC Logo
122 people viewed this question
Top Mathsoft Computers & Internet Experts
Michael Cummings
Level 1 Expert
Bapco
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
