Question about Archos Gmini 400 (20 GB) Digital Media Player
Software corruption? Hello I have been using my Archos for about 3 years and love it. Yesterday, I turned it on and the normally yellow screen was grey - i could still see all the icons, but when I tried to open the music player instead of getting a list of titles I got strange **.bin file and "recycle.bin" file headers. Everything seems corrupted. Is there a way to download the operating system to reset/reboot my Gmini? Thanks
SOURCE: File Allocation Table corrupted
I got rid of the problem on my own, please read below how I solved it.
Basically, the partition of hard drive was still there but with corrupted data about its files indexes. With a free HDD rescue tool I was able to identify the partition and fix the problems regarding its corrupted indexes (file allocation table and toc).
After fixing the problem, the device became fully working and there's no data loss.
Posted on Aug 21, 2008
  • 6 Answers
SOURCE: archos 604 wifi corrupted
Did you try ?
- Using the reset button located under the battery?
- Holding down the LCD button as you press POWER to start up the unit and trying one of the recovery options?
PK
Posted on Jan 10, 2009
Archoshelper
  • 5 Answers
SOURCE: Archos recording corrupted when battery died
There is no solution to this problem i am sorry but you will have to record it over i asked the Archos company themselves and their is no solution
Posted on Feb 22, 2009
SOURCE: I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Posted on Jun 16, 2009
  • 699 Answers
SOURCE: file system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Posted on Dec 20, 2009
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I have a ARCHOS 28 internet tablet and the touch screen is not responding to any contact. what should i do?
We had a similar problem yesterday. It happens as soon as we plug in to USB cable to PC. We found that after we left it for some time it did eventualy kick back in to life. We could use it until we plugged in to USB again. Trying to find a solution to the problem right now. You can press and keep hold of volume up button while you turn back on and that kicks in the diagnostic software menu. From there you can find the "Force screen calibration" which we did but it doesnt sort out the problem of plugging in USB
Dec 25, 2010 | Archos 28 Internet Tablet
Archos 504 wont turn on
Disconnect the battery for few seconds and replace back again, then turn on. I had the same problem and that was what I did.
Sep 17, 2009 | Archos 504 500870 Digital Media Player
Stuck on Archos screen...
well i got to tell you the truth mate archos are **** every mate of mine and me have all
expierenced this problem it will go from this to not
turning on at all - you wont lose your data it wont format
mine just doe sent turn on
Jul 23, 2009 | Archos 605 WiFi Digital Media Player
Archos 400 won't turn on (error code 3)
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Mar 11, 2009 | Archos 404 Digital Media Player
I have a Compaq flatscreen LCD TFT5000 I picked it up used when i pluged it in the colors are all messed up whit has a red hue red is verry bright blue is verry bright and green shows up as Black the...
NO PC stated, 1984 to 2017, 10,000 models, stated.
NO OS stated, XP what? must we guess the OS?
no posted photos, of ugly screens presented by you.
why do that? leave out the #3 most important fact.s
michean, = machine, say "PC runs great, "
no PC stated, no OS stated but it runs great but colors not.
Compaq monitor TFT-5000 ccfl
very very old monitor. 4:3 square screen old.
15 inches sized (tiny)
18 years old in fact, in dog years that be 126 years old,(lol)
in all cases of all PCs made ever,
there can be many causes, no need to guess or for me to list them ALL.
but here is the MACRO view (from afar)
Did it fail plugged in to ANOTHER GOOD PC
no, didnt fail, then,...
1: The PC graphic chip is overheated. ever clean unstated
2: PC has CPU oveheating
3: PC has power supply problems, causing chip to malf.
4: PC video card bad, or if laptop GPU chip problems.
5: PC has corrupted or wrong or virus infected Video drivers.
end.
anyone else with same problem would do tests or through it away, if bad, its has $0 zero dollar street value like this.
ever consider upgrading, to something 2010 or newer. ?
a REAL LED LCD screen. (11 years newer?????)
your screen has CCFL lamps that turn yellow old, and then go dead. yellow make white look yellow.
see?
Oct 16, 2017 | Compaq Computers & Internet
Feb 09, 2009 | Archos 605 WiFi Digital Media Player
Archos 604 wifi corrupted
Did you try ?
PK
Dec 19, 2008 | Archos 604 WiFi Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos Gmini 400 (20 GB) Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
