Question about Weber 847001 (NG) Grill
Washed grill with hose and now it wont start - Weber 847001 (NG) Grill
  • 426 Answers
You need to remove the grills and vents and dry the lighter element and electrodes located on the burner, they work by forcing electricity to just an air gap, which cant happen if its wet or clogged with soap
Posted on May 31, 2010
Riding mower wont crank even after a need battery and ignition switch was put on.
if compression is good and has fuel
not running after the wash down
has to be coil or spark related
May 19, 2016 | Cars & Trucks
How to Troubleshoot hover and tunnel U6476
Hi! Below are step-by-step instructions for trouble-shooting your Hoover U6476.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
May 31, 2014 | Hoover U6476-900 WindTunnel Vacuum
I stuck a pressure nozzle on garden hose and washed 4 " of grasshoppers from the grill/radiator area my 97 Buick Lesabre(245,000 milage) .Now car won't start. Starter tested ok but car...
you got some of the wiring wet, take off the plastic cover on the engine and inspect the wires, they are known for missing insulation or frayed wires on the injectors and some of the sensors
Sep 21, 2011 | 1997 Buick LeSabre
Wont start just bought it it clicks but does not heat
Ensure that your hose, regulator, and control assembly are all clear of debris and that the orifice is not plugged.
May 29, 2010 | Weber Genesis E-310 Gas Grill
My gas grill only gets to 350-375 ,I pressure washed it
Bad Mistake! you might just go get a new one after that! you can clean them with water but not with pressure next time try so oven cleaner and a hose!
Mar 22, 2010 | Grilling
Grill wont heat as it did
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 19, 2010 | Weber Q Grill
My 1991 toyota camry wont start after I washed the engine. I've dried the distributor but it still wont start.
give every thing a good spray with WD40 that may help start her up,, its a bad idear to use a high presher water hose for cleaning your engine up,,
you just found out way that is! she will go again after she has dryed off again,,
Nov 02, 2009 | 1991 Toyota Camry
Charmglow grill wont light with new burners
check the regulator and hose and if it is not that it is probably the washers under the valves take soapy water in a spray bottle spray and look for bubbles
Aug 29, 2009 | Grilling
93 grand cherokee wont start
spray all the electrical components with wd40 then try it
Apr 15, 2009 | 1993 Jeep Grand Cherokee
Weber 847001 (NG) Grill Logo
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
