HP Pavilion 6700 Windows XP
We purchased an HP Pavilion 6700 laptop from Best Buy several weeks ago. It came with Windows Vista installed. We are unable to install and run some of our necessary software with Vista. We found the drivers on HP that should support Windows XP. But we still cannot get the wireless and non-wireless network cards to work. We are unable to join the laptop to our internal domain or access the internet. Are there additional drivers not readily provided by HP that are required?
Sarah Urig
Mega Solutions Group, Inc.
  • sarahrmega Apr 09, 2008
    I had someone at the office follow your instructions above and here are the results:
    The operating system doc says that we have an Atheros Wireless Network Adapter onboard. That’s wrong. We installed the driver and utilities for the Atheros but it fails to associate with the hardware. The HP rep said that this laptop uses the Integrated Realtek (RT8201CL) NIC which supports a 10/100 Mb/s data transfer rate.
    A fellow through the HP forum says we should try the PCI-E drivers from Realtek. He claims they have worked for him on integrated adapters. I’m going to look into that next to see if I can find an XP driver that sounds close.
  • sarahrmega Apr 11, 2008
    I am sending my notes from the downgrade. The “recovery CD” notes are my notes of what files are saved on a recovery CD I made in case I ever have to do this again. Having a list of the filenames might be useful to you so I left them in.
    Driver Recovery CD Instructions and Starting from Scratch Instructions.
    This comes largely from
    with my notes included.
    Downgrading Hewlett Packard dv6000 Series from Vista to XP Pro x32
    HP dv6736nr with AMD Turion 64 and Nvidia Chipset
    1. Chipset Drivers
    First install Nvidia Chipset Drivers, install first and reboot. If offered, choose the option to install ONLY the drivers. Drivers from -
    Note: CPU-Z says the chipset is nForce 560. Use instead the nForce 630a drivers from the above link.
    Recovery CD: Use 14.10_nforce_630a_winxp_english_whql.exe.
    2. Nvidia Video Drivers-Next install Video Drivers from here - You want the 15655.exe.
    Recovery CD: Use the Setup.exe from the folder 156.55 in the Video Drivers folder.
    3. Wireless Drivers-Next install the Wireless drivers, select DRIVERS ONLY when installing. Drivers from here -
    The Atheros drivers worked for me. Recovery CD: Use the setup.exe found in Atheros Drivers/AR5007_XP/WMIa-167G_Windows_Driver_5.3.0.45/Install CD.
    4. Windows Updates. Next go to Windows Updates and install all the main updates only (90) when I did it.
    5. Audio Drivers This one is tricky it’s a 2 stage process. First you need Microsoft UAA (Universal Audio Architecture) drivers from here -
    Download and Install Recovery CD: Use sp33867.exe.
    Note: I found that the new hardware dialog pops up so I left it open and used the steps below to install the drivers.
    Next you need Conextant Audio Drivers from here - You cannot install this the normal way you have to use Device Manager as follows: Unzip to a folder of your choice - remember where - then go to Start > Control Panel > System > Hardware > Device Manager.
    Look down the list for "Audio Device on HD Bus", right click on it and select "update driver", When it asks to go on line to find a driver - NO Select "Install from a list or specific location", and "Don't search I will choose the driver to install"
    In the list of common hardware types, scroll down and select Sound, Video, and Game controllers.
    Remove the check from "Show Compatible Hardware" and click on "Have Disk".
    Next...browse to the Driver Folder you unzipped and click on "WiSVHe5.inf" file. Ignore XPs complaint and select "Install Anyway"
    Recovery CD: Use Conextant Drivers/ConexantHDAudio_221_XP/XP32/WiSVHe5.inf.
    Thanks again for your help.
    Richard Leimbach
Richard, your fix to the audio problem for the conexant 221 worked great. Life saver being a college student and all- thanks for the help``
Posted on Aug 14, 2008
I have a HP 6700. I formatted and installed Server 2003 and was happy but was not able to find sound drivers. HP had me to reinstall vista via recovery disc; but now the machine will not stop rebooting ! I have usd the recovery disc twice over one week period and the only way it operates 'normally' is under Safe Mode with Networking. I used Saundra Lite and noticed that the 80 gig hard drive is partitioned, only 24 gigs are recognized. I am able to format the other 50 gigs via device manager but when I reboot the newly formed partition disappears....please help..
Posted on Jul 31, 2008
  • 202 Answers
Hi sarahrmega
At another computer, please, go HERE and download Belarc Advisor pc audit utility. This utility will audit your pc's hardware and software.
You may want to also go HERE and download CPU-Z (another pc audit utility (it will only audit hardware)).
Now, "sneakernet" those downloads over to the Pavilion 6700 and install/run them.
Post back here w/ the chipset that is identified for your motherboard and any other information relevant to your integrated (built-in) wired and wireless NICs.
This will, hopefully, lead us to where we might be able to find XP drivers for your integrated hardware.
Please, let me know if this response was a "FixYa"
or "Helpful" for you or, of course, if you have
any additional questions, etc on this topic.
If the information I provided you w/ resolved your
problem or lead you to a resolution for your
problem or an answer to your question, then, a
"FixYa" rating would be most appreciated. @:)
It is best to wait until the problem has been
resolved b4 scoring the experts who participated in
solving your problem or answering your question.
(Once you enter a rating, the problem will be
closed and we will not be able to continue to assist
Very often it will take more than one exchange of
information between you and an expert in order to
resolve your problem. If a proposed solution
doesn't work for you, don't rate it yet. Instead,
post back here letting us know and we'll continue to
work w/ you until we find a solution that does work
for you.
Thank you
BJ @:)
Posted on Apr 08, 2008
  • B Joan Rapier
    B Joan Rapier Apr 09, 2008
    Hello sarahrmega
    For my own edification, which one of the PC audit utilities incorrectly identified your integrated NIC?
    Belarc Advisor or CPU-Z? Did you try them both w/ the same results?
    I'm sorry it didn't identify the hardware properly for you. I usually have really good luck w/ these utilities. It may have something to do w/ (in fact, I suspect it does) running the utility from w/in the new operating system. That's the danger of "letting the fox in the hen house". The cleaner way of identifying hardware is to exclude the operating system from the process. Unfortunately, those utilities are harder to find and more difficult for the average user to run and to interpret.
    You are more than welcome to post another Problem related to this issue and we'll pick up where you are w/ it now. Otherwise, good luck to you. You're very resourceful. I'm sure you'll do fine.
    I would be interested in learning if you were able to find XP drivers for that integrated NIC, though.
    If you don't mind, would you send me an email ( and let me know?
    Thank you (and thank you for using FixYa!)
    BJ @:)
  • B Joan Rapier
    B Joan Rapier Apr 11, 2008
    Thank you for doing that, Richard. (posting your notes and links) That was very thoughtful of you.
    I'm sure it will help others who come along later.
    BJ @:)
  • 871 Answers
Hi sarah
vista has still so many problems regarding compatibility issues. howevr, there are already many fixes to that problem.
if you go to HP website, im sure youll find out there what your looking for.
btw, about your questions, there are no extra drivers required . those drivers are pre-loaded already in vista. what you want to look for are drivers that are vista capable to your wifi card.
How can change my operating system
To change the operating systems say from Windows XP to Windows Vista or Windows 7 you need to purchase Windows upgrade disk or a full version of the Windows installation disk.
You boot up with this Windows installation CD to install the new operating system and follow the screen instructions.
Sep 30, 2010 | HP Pavilion dv6000z PC Notebook
My HP pavillion dv6700 laptops sound doesn't work .... the icon has a re x at the bottom and it says no audio device has been installed; it is only 2yrs. old; can this be resolved or would it be best to...
I believe it can be resolved without purchasing a new laptop.
Windows is a 'funny animal'. Sometimes Windows just looses it. You need to reinstall your audio device Drivers again.
It's Integrated Audio used on the HP Pavilion DV6700T laptop. An audio chip soldered to the motherboard.
Another term used for Integrated Audio is OnBoard Audio.
On the motherBoard.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
(If it wasn't Integrated Audio, it would be a separate audio adapter card. {Sound Card} The audio chip is soldered to an adapter card. The adapter card is removable. This would allow replacing the audio adapter card. Not happening for an HP Pavilion dv6700t laptop)
Drivers are small software programs that allow the Operating System to communicate with the device.
(Windows XP and Windows Vista are two examples of an Operating System. O/S)
There is an HP Pavilion DV6700T Entertainment Notebook PC series, and an HP Pavilion DV6700T SPECIAL EDITION Entertainment Notebook PC series of laptops.
I need to know what Operating System you are using. Do I assume Windows Vista? (Windows Vista Home Premium 32-bit)
Going with Windows Vista, here is the Audio Driver download page for the Pavilion DV6700T notebook, (Laptop),
Doesn't matter what version of Vista it is, this audio file is for all versions of Vista.
On the above page left-click on the + sign to the left of -
Driver- Audio (1)
Now go to the right, and left-click on Download, in the rectangular box.
A small box will come up, Opening sp38899.exe
The name of this file is sp38899.exe
Left-click on Save File.
The file will be saved to, where ever your downloads are set to save to. The file needs to be found, then opened in order to work.
When you see the audio file (sp38899.exe) Double-click on it.
The Windows Installation wizard will lead you through installing.
If you are asked to restart your computer, do so.
If not, restart your computer.
Sep 27, 2010 | HP Pavilion DV6700T Notebook PC
I want to download a video card driver for my laptop hp pavilion 6700
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
Nov 17, 2009 | HP Pavilion dv6000z Notebook
Downgrade to XP
Looks like they do not have very many drivers listed for XP on their site, but all of them (obviously) for Vista. I would recommend you not downgrade to XP with that particular laptop. Sorry!
Apr 16, 2009 | Microsoft Windows Vista Ultimate Edition
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Hp Pavillion ze4900
the way things sound, you definately need a new hard drive and battery. as for saving the information, thats a little dicy. its more than probable an expert can, but it may turn out to be difficult. As for where to send it, i'd say take it to the closest best buy and they will be able to help you amptly.
You will only have to upgrade to vista if you buy a new computer as a whole. you can still stay with 2000 if thats what you prefer.
Jun 03, 2008 | HP Pavilion dv4000 Notebook
Free replacement of windows vista by windows xp professional in acer aspire 5315 laptop
You can install windows in any computer and hardware shop neear your area or the best is get it done from (nehru place) The ITHub of india .....
They will charge you Rs 300 approx
Feb 15, 2008 | HP Pavilion dv6000z Notebook
XP Drivers for HP Pavilion DV 6516 tx Laptop
well going back to xp may not work ok and xp is very slow and buggy vista alot better u need to cheak for updates on vista and run cccleaner what ideams do u wann conectto pc that wont work
Feb 03, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
4,672 people viewed this question
David Payne
David Payne
