Sanyo Katana SCP-6600 Cellular Phone Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It won't charge anymore and I have tried different cords and different outlets.
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on May 31, 2010
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
14870
Points
229
Hi, is possible the charging port is bad.. that is why its not charging..try repair the port.
cheers
My asc vital tablet/computer won t charge
I would try using another charger and plug and power cord to see if it will charge again and another power outlet too. If it is still not charging then the battery needs to be replaced.
How do I fix my Toshiba tablet that won't show me that it is charging?
Have you checked the following:
  1. Power cord for breaks
  2. The power outlet you are connecting into (try at least 2 other outlets before settling, but use different outlets for the sake of argument.
  3. When was the last time you charged and it actually did?
  4. Do you have the correct cord?
  5. Have you tried to replace the cord?
My ipod won t charge
It could be 1 of 2 things. The first 1 I have had the experience of accidentally leavng my iPod plugged in charging for over a day. What happened...it killed the ability of the iPod to hold a charge & yes I tried with another battery & it was a no go. The second issue could be that your actual power supply cable has gone bad and won't work anymore. Now you didn't specify on which manner you're trying to charge it so if I didn't address your issue my apologies. There is a 3rd thing and no its not a combination of the 1st 2 I mentioned happening in conjuction...The 3rd thing could be that the power outlet you're trying to use doesn't work anymore so try another outlet plug.
Won't turn on
Have you tried a different AC outlet? A different Cord/Charger? Has the AC jack been damaged? The on/off switch damaged? Is the battery Charging? Need more info.
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
My laptop will not charge anymore....whats wrong with it?
have you tried using a different outlet? or maybe a different cord? or even a different ac adapter? also try to use a known good battery to isolate the issue. if those options wont still solve the issue, possible motherboard replacement is needed. might be that the port is damaged.
2answers
Thanks
Do you charge it from an outlet of via usb cord? If from an outlet, the charger just might not work anymore, but the usb cord that you use to put media on the mp3 player will charge it also.
Top Sanyo Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
 Mikey
Mikey
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
