Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Blowing the 5 amp fuse - Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
  • 146 Answers
You have a short in your low voltage wires or a bad contactor coil
Posted on May 31, 2010
What size fuse would I want on my cd receiver head ? I was blew them and thought it was 5 amp but they keep blowing after I put in 5 amp fuses ..would it hurt to try 15 amp?????
I would say that if you are blowing a 5 amp fuse and are not pushing the system hard, then you have an issue. You could try a larger fuse, but make sure you look for hot spots and smoke. I would bet you either have a shorted wire or will need to replace the unit.
Aug 12, 2015 | Cars & Trucks
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
Can I use a 5 amp 240v AC domestic fuse to replace 5 amp 12v fuse
A fuse is rated for it's current carrying capacity so yes you can use a 240 volt 5 Amp fuse in a 12 Volt circuit.
The Voltage is given to indicate the insulation of the fuse, i.e. if you used a 12 volt fuse in a 240 Volt circuit it may arc and therefore is not suitable. You can always use a fuse with a higher voltage rating in a lower voltage rated circuit.
A 5 Amp fuse will carry 5 Amps indefinately and will only blow at 2 or three times it's rated current.
Oct 26, 2009 | Max American Terminal 30 i Fuses
Cub Cadet zero turn:Engine starts and runs about 5 seconds before blowing 20 amp fuse.
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Aug 24, 2009 | Mtd Gold 42" Zero-Turn Mower -
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
73 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
