Question about Honeywell Programmable Thermostat Heater
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that there was a red wire on my old thermostat that was hooked to a teminal marked 1 on one end and then tied in with the Y wire on the other end. How do I connect that wire to the new thermostat? Thank you
    Guru:
  • Honeywell Master
  • 587 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Jun 01, 2010
  • mcsalay641 May 10, 2011
    Did you get your answer? I have the same old thermostat with the same jumper wire. Any help would be appreciated.
  • Bill Long May 13, 2011
    In a gas fired furnace, the jumper wire from #1 to Y is for auto fan control in cooling for that thermostat and you don't use it on the new thermostat.
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
Honeywell RTH221
Try bypassing the control board by jumping the L1 wire with the high speed motor wire, if the motor runs then the board is faulty and must be replaced. If the motor does not run either the capacior is bad or the motor itself
Jul 08, 2012 | Honeywell Programmable Thermostat Heater
Old thermostat has 2 wires. how to I wire my honeywell rth111/rth221? thanks, Rich
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2060EFS.pdf this should be the instructions for that t stat. best to just look at which color came off what letter and replace back on that letter. you dont know if the last guy wired it right
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell RTH111/RTH221 I put de red wire ont Rh, but where do I put the black wire? Thanks!
If you just have two wires and it controls heat only put black wire on W, or W1 if there is no plain W
Jan 22, 2011 | Honeywell Programmable Thermostat Heater
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
708 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
