Question about Craftsman 27cc 2Cycle Full Crank Curved Shaft Weedwacker Gas Trimmer ()
My craftsman weed trimmer starts and runs when choked but stalls when un choked and when calling for full gas. Is the fuel filter bad?
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
#1 Taper
  • 1041 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
  • 168 Answers
SOURCE: Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: craftsman eager-1 3.75 mower will not stay running
Most of the starts but dies problems are caused by dirt/water/debris in the carburetor float bowl.
You can try draining the gas out of the carburetor float bowl by removing the float bowl nut located on the bottom of the carburetor.
Make sure the hole in the float bowl nut are clean. If the problem persists after draining the float bowl nut you will have to remove, dis-assemble and clean the carb with compressed air and carb cleaner.
Posted on Aug 20, 2009
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
May 04, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 27cc 2Cycle Full Crank Curved Shaft Weedwacker Gas Trimmer () Logo
163 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
