Question about Dell XPS 420 PC Desktop
HP Pavillion pc doesn't boot up ... no fan, no start sound, nothi
The back of my HP Pavilion computer a1310n shows a blinking green light next to the power cord insertion point and it doesn't boot up, no fan, no start sound, nothing .. ideas? thank you
  • Anonymous Mar 23, 2014
    my a1310n powers on and both fans run, I get nothing on the screen, what could be wrong
  • Dell Master
  • 5,660 Answers
Bad Power Supply.
The blinking green light on the power supply, is a diagnostic light that indicates this.
Suggestion is to;
1) Test the Power Supply voltages
Or
2) Replace the Power Supply with a Known to be good, Compatible unit, for a test.
[Compatible:
A) It is an ATX style of power supply.
The style used by 90 percent, of personal computers out there.
Example: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4975140&CatId=106
The test Power Supply unit should be mounted in the computer, for testing.
The power cables only reach so far, plus it is safer.
B) At least a 250 to 300 Watt unit, for a test unit. More Wattage is okay.
(The power supply that comes with the Pavilion a1310n, is a 300 Watt unit.
The 250 Watt unit stated above is just for a Test.
You are testing to see if the Power Supply is the problem.
More wattage is okay as a computer only uses what it needs.
If you have a 1000 Watt power supply installed, and the computer only needs 100 Watts; the computer only uses 100 watts.
The computer Will Not burn up, by installing a power supply with more Wattage than the original)
C) Correct amount of power cables, and correct kind.
Observe the power cables from the existing power supply, that are plugged into the various hardware components in the computer, and to the motherboard.
The test unit has to have the same power cables, and the correct amount of them.
Need help identifying these power cables, reply in a Comment.
The above may sound funny. Who has a spare power supply laying around, other than someone really committed to computers?
You may find yourself, or someone you may associate with, has a computer sitting in a closet, basement, attic or garage, that has a working power supply, (And is compatible), and can be used for a test unit.
Test the Voltages.
There are three main Voltages, produced by a personal computer power supply.
(DC. Direct Current)
1) 3.3 Volts (Wires that have Orange insulation)
2) 5 Volts (Red wires)
3) 12 Volts (Yellow wires)
(Two D cell flashlight batteries are 3 Volts {DC)
ANY Black wire is a Ground wire.
Use an economical multimeter to test the Voltages, or a power supply tester.
Multimeter:
Power Supply on.
Positive probe lead (Red) connects to the power wire to be tested.
Negative probe lead (Black) touches ANY Black wire.
(Black insulated wires are Ground wires)
This is one example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
What causes Power Supply failure?
A) Inside of computer is dirty, as well as the inside of the Power Supply.
Computer unplugged from power, (Computer case open, and anti-static precautions observed), a can of compressed air for computers is used on a regular basis as needed, to help prevent this.
There are two cooling components for a SMPS.
(Switched Mode Power Supply)
1) The internal fan
2) The Heatsink's inside
http://en.wikipedia.org/wiki/Switched-mode_power_supply
A Heatsink, is an object used to draw heat from whatever hardware component, it is placed against.
A Heatsink is generally just a flat, square piece of metal, that has tall, thin fins protruding from it.
The flat metal base absorbs heat, whereby it is absorbed by the tall thin fins, and radiated away.
In the case of a Power Supply, there is an internal fan which draws air in-between the fins, helping to carry the heat away.
Once the fan blades, (Plus center hub, and surrounding cage), become coated with gunk, and the Heatsink fins become coated, the cooling capacity drops tremendously.
Heat = Wasted Energy.
The Power Supply has to produce more power, to keep up with loss of energy.
Eventually hardware components inside the Power Supply fail.
B) Cheap quality components used in the power supply. (Cheap quality power supply)
Awaiting any question you may have regarding this.
Post in a Comment.
(Believe upper right of your page)
Posted on May 31, 2010
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Insert boot disc error on hp pavillion a622n
Boot disc error indicates that your computer is unable find any Operating system to boot up. Go to BIOS settings and figure out if your BIOS detects your hard drive. If so, format your hard drive and install an operating system.
I would love to hear from you in regards to this concern.
Sep 07, 2012 | HP Pavilion a1310n PC Desktop
Problem stating up pc
check to see if your vga cable is properly connected at both ends i.e. at the monitors end as well as the computers end. In case it doesn't solve the issue then your vga port is damaged.
Aug 15, 2012 | HP Pavilion a1310n PC Desktop
HP Pavilion a1310n DVD Writer 740b running XP....doesn't recognize CD-ROMs (but it will play DVDs). Tried PC Doctor and various FixIts but to no avail.
Have you tried uninstalling the drivers for the reader itself? if not, Uninstall them and reboot, xp should reinstall the drivers automagically and see if that solves the problem.
Aug 28, 2011 | HP Pavilion a1310n PC Desktop
Hp pavillion 533w wont boot up green light on front comes on but thats it no fans coming on either
Hi ,
If the green light comes on on the front panel then it means the fan is spinning so what u can do is a self test for the monitor.Disconnect the vga cable from the back panel of the computer tower and then check if there is a message displayed on the monitor that should say check video signal or no inoput signal ,if there is no such message displayed then it means the monitor is a fault .If not then reset the memory card and then check .U can also run a test for the motherboard to do this u will have to remove the memory card and then turn the computer on if u hear long beeping noise it means the motherboard is fine .If u dont hear any sound then the mother board needs to be repaired or replaced...
all the best
May 01, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Dell XPS 420  PC Desktop Logo
808 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
