Question about GE APN10AA Portable Air Conditioner
How do I attatch a direct drain line to the ge ape08akm1 air conditioner
4 Suggested Answers
  • 16 Answers
SOURCE: GE air conditioner
what type of unit is it, window ect?
Posted on Jun 07, 2007
mastatech
  • 478 Answers
SOURCE: Not draining
It has to be angled slightly toward the back to the pan under the bck coils and out to the outside, good clean water great for plants and pets.
Posted on Mar 29, 2009
heatman101
  • 43501 Answers
SOURCE: my ge window air conditioner
On many of the newer air conditioners they intentionally keep some water in there so that it splashes onto the condenser coil and helps to cool it....while this may work well it also creates more noise....so I often recommend to drill a drain hole in the back corner...jus drill down from the top...drilling up from the bottom is a great way to drill right through the coil....
heatman101
Posted on Sep 01, 2010
When i plug it in it makes a beep noise but the display doesn't come on. it there a reset on this unit? ape08akm1
There is a sensor that detects when the unit is iced up. IT sounds like the sensor is bad or the controller for it is bad.
Jun 04, 2013 | GE APN08AA Portable Air Conditioner
I need to know where the recharging valve is on G.E. conditioner . Model # APE08AKM1
Typically there is no access valve on window A/C units...
To gain access you must install one yourself...
Click here
This is what you need to do that..
heatman101
Jul 20, 2011 | Fedders X Chassis A6X06F2A Air Conditioner
I have a GE APE08AKM1 portable A/C unit. The first summer it blew cold air.The next summer it was so-so. This summer it just blows It believe it leaked the freon or what ever it uses out. Is it cost...
sounds like it has a very small leak. Unless it can be detected Its
probably not worth it,
unless you have a ser man to add ea. year.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 02, 2010 | GE APN08AA Portable Air Conditioner
Air Conditioner (RUUD model: UBHC-14J06NFD) is leaking water from bottom. It is causing a major puddle in Air Intake area.
The condensate drain line/pan is clogged causing the condensation to overflow the pan.
The easy way to fix that is attatch a powerfull wet/dry shop vac to the end of the drain line and such out whatever is causiing the clog. Also take off the panel to the evaporator coil and clean out the pan with the shop vac.
To double check that the clog has been removed, pour a gallon or two of water into the pan and ensure that it is draining properly.
Oct 11, 2009 | Heating & Cooling
When the ac unit is on the water comes in the house
The condensate drain line is clogged, causing the condensation water to overflow. You can use a shop vac to clear the line. attatch it to the outlet side of the line. also clean out the condensate drain pan located at the bottom of the indoor coil.
Sep 25, 2009 | Amana MH09A3PA235 Comfort Zone Room Air...
Ge ape08akm1 portable ac unit
the port out the back has to be pushed down so it angles down. If its level it will drain into the tank
Jul 27, 2009 | GE APN08AA Portable Air Conditioner
Drain hose in floor drain but fills up water bucket
wow, that's a weird one there. just to check, you did turn thr drain connection all the way down and remove the cap? nothing inside the drain connector? the hose is not too small or run too far? is the water coming out of the hose and in to the bucket at the same time if it is I would think ther is an internal leak somewhere and take it back for an exchange if new. good luck let me know if this wasn't any help for ya
seth
Jun 12, 2009 | GE APH10AA Air Conditioner
How does condesate water drain out of the ge aem25dm a/c? is there any drain lines to hook up under the ac?
It drains from a formed tray on the evaporator side of the AC. Now if the drain is blocked or the AC or the air conditioner is not tilted slightly down on the outside the water will pool up in the front cold side evaporator tray. If all of those that I explained are ok then unplug the AC and remove it from the housing cover and clean the drain being careful not to get the electric fan motor windings wet as this will cause them to short out when turned back on. If you need further assistance let me know, Thanks, Sea breeze
Jun 11, 2009 | GE AJCQ08ACB Air Conditioner
GE APN10AA Portable Air Conditioner Logo
85 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
