Question about Akai LCT3201TD 32 in. LCD Television
AKAI LCD, no tv signal, dvd player still works
SCE installed a new meter in my home last week, resulting in a power loss. When the power resumed, my Akai tv/dvd player did not work. the tv displayed a message, "no signal". We assumed that there was a problem with Dish Network, my husband checked all connections, Dish tried to troubleshoot. \My husband connected another tv to the cable and it worked! The dvd player still operates. Any ideas? Could this be the result of a power surge?If it's something simple, I would like to fix.
  • 2318 Answers
SOURCE: Akai
There are reports that the power supply has dry o leaky capacitors. If you open the TV you will see the power supply # MLT169A.
I have fixed a few of this power supplies.
Posted on Apr 09, 2008
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
SOURCE: Remote code for Akai 37" lcd with Dish Network
Akai support 216-454-0864 .I have the same problem and called the support phone. The answer is this TV came without a code programmed in it.
Posted on Oct 06, 2008
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Posted on Mar 16, 2009
spr1949
  • 1182 Answers
SOURCE: AKAI LCD TV/DVD Player Combo connect to Motorola DVR Cable Terminal
Please follow guidelines given in operation manuals of both.
Posted on Aug 03, 2012
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
No signal
do you have another tv ?? so you can test the cable.
sometimes the cable gets corroted by the distribution box and will obstruct any signal or if you do have signal " on another tv " the cable input on your akai is probably broken, if you have the skills try to open it up as see around the cable input box, most common they get un-solder or loose and won't detect any signal
Jan 08, 2009 | Akai LCT2715 27 in. LCD Television
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Oct 07, 2008 | Akai LCT2721AD 27 in. LCD Television
NO sound and cable signals
Looks like someone sold you a unit only partially working.
You may need to have the main board replaced, which is likely why the previous owner sold it.
My solution would be: Buy an inexpensive surround system and a VCR, Use the VCR as your tuner, and plug the audio output from the VCR into your surround system.
This way you will have a tuner (the VCR), and sound through the surround amplifier. You can also plug the audio output from your DVD player direct into the surround amplifier. This solution would likely run you less than half the cost of replacing the main board in the TV.
May 07, 2008 | Akai LCT2060 Television
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
AKAI 20" TV w/ DVD Player Model # CFTD2052
Your problem could be a backlight problem. But the bulbs may not be the source of your problem, as both and sometimes 3 or 4 bulbs, depending on the set will not all go out at once. You most likely have an inverter problem with your set, that is the circuit that powers the backlights. Good Luck
Mar 30, 2007 | Akai CFTD2052 20 in. EDTV-Ready LCD...
Akai LCT3201TD 32 in. LCD Television Logo
64 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
