Question about GPS
SCREEN HAS WHAT APPEARS TO BE A BURNT IMAGE BLOCKING MOST OF THE SCREENS DATA. WHAT CAUSED IT AND CAN IT BE REPAIRED. PURCHASED IT IN JAN. 1997 AND THIS IS THE FIRST TIME I HAVE HAD A PROBLEM...
  • 6,487 Answers
Base from the description of your problem this is a problem with the inner LCD part that gone bad already , the only way that this can be fix is to have the LCD replace , you can take it to service center near you for the replacement.
Posted on May 31, 2010
Leappad II ultra cracked screen
probably not worth it to repair. custom sized screens. Replace
Mar 12, 2014 | Video Game Consoles & Games
Vizio VW 32 L HDTV screen appears to be cracked . Can it be repaired?
Unfortunately, a cracked screen cannot be repaired insofar that it would cost the same as simply giving you a new unit.
Be sure to check if you purchased any sort of coverage that may allow you to get a replacement unit at low-to-no cost. The warranty that comes along with the product will most likely not cover the damage unless you can prove it was a manufacturing defect that caused the crack.
Mar 01, 2011 | Televison & Video
JVC GR-D72U When turn on the cam in Auto or Mode mode is no view on the both screens. I can see all parameters on lcd screen, but can't see the landscape. Tried to REC , but steel can't see nothing in...
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 05, 2011 | JVC GR-D770 Camcorder
Sharp MX-6201n get e7-06 error when scanning to thumb drive
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Oct 08, 2010 | Sharp Office Equipment & Supplies
Samsung D900i Screen image sometimes reversed. Screen goes blank and image moves randomly
Hi
I can tell you how to solve the reversed image. With the camera running look on the side of phone where the up/down volume keys are. If you press up button you will notice image on screen change. I think the down button inverts the image? Up or down this should correct your inverted image problem.
With regards to people experiencing lines and blacked out screens this appears to be a phone fault.
Jul 15, 2008 | Cell Phones
No blue colors projected on screen
Only a few causes for this problem. "Splotches" are usually caused by dust in the light engine which can sometimes be blown out using compressed air. Pink picture is caused by either data or burnt lcd card. Procedure for data is: put tv to ch. 3 and turn power off. simultaneously press input and power on set for three seconds to access service menu. Be very careful not to change settings other than what needs changed. These adjustments are changed using directional arrows. Navigate to "memory init" then hold (r) arrow button for 5 seconds. You will know if it worked. Then exit and/or turn set off. Please let me know if this is successful as I have additional info you may need. Good luck, Russmann.
Jun 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
DSC-T3 Sony, Image from the lense is not diaplayed on the screen
Yes , this is very common with T3 : it is caused by faulty CCD sensor ( see enclosed pic of a sensor and lens assy . ) and this needs replacing . Good news is that Sony will repair free of charge.2bcdbc0.jpg
Dec 05, 2007 | Sony Cyber-Shot DSC-T3 Digital Camera
Image burned into screen
The image you see is burned in the CRT's,nothing wrong with
screens.As you might expect, red,green and blue CRT's are
very expensive,about 400.00 each.
Nov 14, 2006 | Toshiba TZ55V61 55" Rear Projection...
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
