Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Zanussi fridge zx99 / 5w not getting cold
Hello everyone.
Our Zanussi Fridge freezer - model no zx99 / 5w has stopped getting cold in the fridge. I have looked at the posts on here for help, so today I took the back off the base of the fridge and cleaned out the inlet fan, and the matrix at the bottom, front and back.
I removed the light pannel in the frigdge with the controls on it, and a bar runs into the back to the thermostat.
I would like to know, how to remove the pannel in the back of the fridge, without breaking it so I can change the thermostat.
Our problem is the freezer works, it freezes fine, but for a few months the temp alarm kept beeping , would not stop, even after pressing it, and the temp light stayed on, but the fridge was cool and all was running ok. Now it wont get cold at all.
You can hear the motor running, it runs for a while, then goes off. It sounds like its behaving normally. The fan spins up and it makes all the usual noises, but the fridge wont get cold. Can anyone help?????
My beers are warm and we have to get milk in small amounts. The model we have, has the control pcb in the base. I have taken the freezer apart, removed the pannel in the freezer, to find lots of wires plugged into various connectors. There was no obvious frost or anything frozen. A pipe runs up the back of the freezer to the fridge and can be seen on the left. I have seen pictures of another bigger fan, and want to know, is the fan in the back of this model the only one? What would I need to change, eg the thermostat? I have had the fridge off all day, cleaned it etc and lloked for faults but dont know what I am looking for! It all seems fine with nothing broken, no wire problems etc that I can see.
On plugging it back in, its fired up and seems to be working just the same, but the fridge wont get cold. Its £70 for a call out here in the Uk and I have no idea if they would be able to fix it so I am desperate for help!
Cheers! Wish my beers were cold!
SOURCE: Zanussi ZX99/5SI
I had this problem with my ZX99. In my case it was caused by faulty temp sensors not making the defrost system kick into place. The defrost cycle works by heating an element for every week or so for a few minutes.
Posted on Aug 01, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
dutchman05
  • 487 Answers
SOURCE: every 4 hours the fridge
sensor is broken. Normally it creates a little vacuum in the fridge( cold air shrinks) and if you have an airleak in your door seal or the sensor is broken
Posted on Apr 24, 2008
SOURCE: I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Posted on Nov 01, 2008
guly
  • 67 Answers
SOURCE: zanussi zx99 fridge fault -
the problem is very common full out the plastic cover inside the fridge, check the heater glass heater or allominume heater check the continuity of the said heater if ok, check the thermal fuse conecting the wire of the heater, very small thermal fuse have plastic cover, good luck god bless boss_frnd@yahoo.com
Posted on Dec 13, 2008
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Fan is rattling on zanussi fridge freezer how can i get at it or ny suggestions as to what the problem is
might be ice on the fan.....when its completely frozen your fridge part will stop working.
Feb 28, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Apr 13, 2008 | Zanussi Refrigerators
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
230 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
