Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Freezer is continuously running, some frost build up on back wall in freezer, fridge does not seem to be cooling properly and some moisture inside top of plastic containers in fridge.
  • tgpettit May 31, 2010
    Does this solution address the freezer continuously running too? Also, this issue with gas is that something we can do or do we need to hire someone to do this?
  • tgpettit Jun 02, 2010
    Great job! Thanks!
    President:
  • 949 Answers
It sounds like there is a defrost problem starting. What you will need to do is unload the freezer, take the shelves out and the panel off behind the shelves. This will expose the evaporator(cooling coils). If there is a frost build up on those then the problem is defrost related.
All the cooling takes place on these coils for both the fresh food side and freezer, the fan just above those coils moves air to the fresh food compartment and around evenly in the freezer. If frost builds up and air cannot flow easily you will loose cooling.
There are 3 defrost components, one of which is bad, A heater, a thermostat and a control. If you can send me your complete model number and brand from the tag on the refrigerator I can walk you through how to test each one.
Posted on May 31, 2010
  • 5 more comments
    We have a GE model-- side by side refrigerator.
    Model number GSH25JSTA SS
    It's only 3yrs. old. Is this issue common in a refrigerator? The reason I ask is because when we first bought the refrigerator the mother circuit board was bad upon delivery and then the water line in the freezer door kept freezing up (we had to install a part in the door to keep it warm). Now here we are with this issue-- ugh.
    We truly appreciate your help and any solutions you can provide. Thanks.
  • Philip May 31, 2010
    Defrost issues are the most common problems that are seen for refrigerators in general not cooling. GE has a fair number of them but I would not say too much more than other brands.
    To check the components on your model, we will need to take the back panel off and at the bottom of the coils there will be the heater part number WR51X10055, it looks like the first picture below. If you disconnect the wires to it and use an ohm meter it will read under 100 ohms if good, you may be able to see it burned if it is bad.
    The second component is the thermostat part number WR50X10068, it is located on top of the evaporator coils. It should read 0 ohms when cold. If it is bulged out or distorted it is bad.
    The heater runs about $35.00 and the thermostat runs about $12.00.
    If both these are good then the issue is the main control, the same part they replaced before.
  • tgpettit Jun 01, 2010
    I took the back panel off inside the freezer. There was a big block of ice on the coils. I used a hair dryer to melt the ice. I tested both the heater part and thermostat part with a meter. Although, I'm not the best at using a meter. When I was testing the heater part, I had readings from over 100 to 22.
    When you say being able to tell that the heater part is burned out, what does that look like? The glass tube is cloudy and greyish/blackish-- almost like what a lightbulb looks like when it's gone bad. Does that sound like it's burned out?
    The thermostat part is not bulged out or distorted and it read O ohms of course I don't think it was cold at the time.
    Let me know what you think based on those findings. Thanks.
  • Philip Jun 01, 2010
    Yes this does address the running all the time issue.
    As far as the gas goes, I think you are talking to a couple of us here and I cannot see what they are writing to you.
    If it refers to needing gas, freon or refrigerant charged into the system, that is not what is needed here from the frosting up coil symptoms I see you have, you have a defrost issue not a leak.
    Let me know if you have questions.
    I responded once to another person, but I didn't like his solution. You have been much more detailed and accurate. I definitely think there is a defrost issue.
    I was asking though-- you mentioned that I would be able to tell if the heather part was burned. What does that look like?
    It looks cloudy and greyish/blackish around the glass tube-- almost like a lightbulb that went bad. Let me know if you think it's bad. The reading on the meter was from 22 to over 100-- I'm not sure why it was jumping so much.
    Where do you recommend buying parts too?
    The meter reading should be somewhat stable but if the ends where you are connecting the meter leads to are corroded or your fingers are touching the metal while you are reading it will fluctuate. Looking like a burned out bulb concerns me a bit. If there is a burned spot or spots and even if it checks good it is most likely on its way out, and would be good to replace while you are in there anyway.
    To purchase parts I would check your local yellow pages for 'Appliance Parts', that way if they are wrong or damaged you know right away. You can also order online from one of many sources. Here are a couple
    Repairclinic.com
    partsdirect.com
    appliancepartspros.com
    Thank you for your advice. I replaced the heater element yesterday. Your advice was so helpful even down to checking the yellow pages for an appliance parts store near me. Only time will tell if that was the issue, but it seems to be working fine today. Thanks again!
    Genius:
  • 1,417 Answers
what you need to do first of all is remove all item in the fridge and clean up all the dry in the fridge while cleaning up you will note that there is
this simply means that the level of the gas in your fridge is low it need to be refill up again through the compressor this is the reason while it not cooling properly and has given a room for the moisture to be present in the fridge
note this refrigerator system is not a place that will should fine any form of parasite
the solution for your not cooking properly is to refill the gas level and the fridge will work fine again
the compressor mention above is like a black at the back of the fridge it need to be refill
thank you and thanks for using fixya .
  • Oloyede Monsuru May 31, 2010
    hello.
    the solution giving to you is to guild you right to do the fixing your self
    please note, if you did not have the technical skill and the tools to carry
    out this assignment then you will have to contact a technician to do the fixing for you
    thank you
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Whirlpool side by side not cooling
The round object is the compressor. Is it running continuously, or is it clicking on and off every 2 or 3 minutes? There also should be a fan beside compressor. Is it running? Also check Fan in freezer to see if it is running. Is there any frost build up on inside back freezer wall? If fans are working and compressor is running continuously and there is no frost buildup in freezer, then you most likely have a sealed system problem meaning its low on freon or there is a blockage in system.
Oct 31, 2017 | Whirlpool Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
I have a Kitchen Aid Model KSRB27FHSS02 Side by Side and the fridge is working fine, but the freezer is not working properly. All the food in it is starting to defrost, what do I do???? I cleaned the...
Hello there:
If the freezer seems to be Is the thermostat knob turned to the proper setting? Is the compressor motor running? It's a football-sized case with no apparent moving parts on the outside of the freezer at the back near the bottom. Is it humming or making any kind of continuous noise? If it is, but your freezer is still not cooling at all, there may be a serious problem with one or more of these areas: The compressor The condenser The evaporator You can't service these yourself. You need to contact a qualified appliance repair technician. If the compressor isn't running but you do have power to the freezer, there may be a problem in one or more of these areas: The compressor The overload and relay The defrost timer It cools poorly or it's all iced up If your freezer cools but doesn't get cold enough, it may have a problem in one of several areas. To better understand the proper operation of a freezer, read about freezers in the How Things Work section of our website. In a self-defrosting freezer, poor cooling often results from a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel inside your freezer. But if you see any frost or ice build-up on the inside walls, ceiling, or floor of your freezer, it's a sure sign of frost build-up. And that's a sign of a problem with the self-defrosting system.
Nov 14, 2010 | KitchenAid Architect® Series II KSRB27FH
Freezer seems to be working properly, but fridge cant keep temp
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 25, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Freezer works great but food is spoiling and not cold enuff in fridge. dosent seem to be air flowing out of vents in the side in fridge. is there a fan that quit or could it need freon
when you fridge is running open the freezer door and listen for a fan there may aslo be on ein the fridge compartment,also look for frost build up on the back wall of the freezer.if there is ice build up you need to defrost it.when the unit is in the cooling mode and you do not here the fan running on the inside of the unit the the fan needs to be replaced.
Jan 31, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
My refrigerator is not keeping my food cold or frozen!!
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Mar 24, 2009 | Kenmore Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
