Question about Craftsman 22" Gas Hedge Trimmer
I have pulled the cord out of my gas powered trimmer. What is the easiest way to fix this
  • 56 Answers
Remove the pull start mechanism, remove the old rope from the inside plastic, thread a new rope through the hole in the outside and through the hole in the plastic center where you removed the old rope, Now reach between the spool and the edge of the casing and pull some slack in the rope, there will be a notch in the spool, set the rope into the notch and begin spinning the spool to make tension in the spring ( correct direction is the same way the rope is spooled in. go until you have good tension on spring, grab rope left outside casing and pull through, then let rope get pulled into the spool with the spring tension you have created. Now just reattach the handle.
Posted on Jun 14, 2010
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
The starter pull cord on my gas trimmer will not pull.
Hi Mark
Perhaps a bit late now.... Just spotted this so I imagine it's all fixed by now.
But for others with this sort of problem.
Assuming the pull cord is not broken, stuck or tangled. Switch off or short plug to ground, for safety then remove the spark plug to allow the engine compression to escape. You should be able to turn the engine over really easy with the pull rope, otherwise the engine might be seized or the rotary pull mechanism jammed.
Also... can the shaft to the string line be rotated as in the crankshaft of the engine.
Good Luck
Aug 30, 2014 | Echo New String Trimmer SRM-225 2 Stroke...
On my 17" straight gas trimmer the pull cord will not retract, how can l fix this please, thanks
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck!
Please vote on this solution.
Aug 30, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Pull cord won't recoil
the recoil spring may have broken and should be inspected and replaced
Jul 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Pull cord will not retract
This takes some mechanical skill and knowledge to fix...definitely would take it back..I would have thought these manufacturers could have fixed these idiotic quality control problems by now....it goes on and on and....I know, folks would say..ya get what ya pay for....so in this case, you paid for a useless machine that you never even were able to use...that is NOT what you were SUPPOSED to get now was it!
Jul 14, 2010 | Husqvarna 28cc Gas Line Trimmer
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Craftsman 17" 25cc Trimmer...pull cord stuck
it's doubtful that bad gas caused this, it sounds like the cord was back-lashed and partially came off the recoil pulley. Remove the recoil cover and ensure the cord is all on the pulley, make sure the rewind mechanism works smoothly before re-installing.
May 07, 2009 | Craftsman 25cc Gas Line Trimmer
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Craftsman 22" Gas Hedge Trimmer Logo
306 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
