Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
My Legend cleaner (8 yrs. old) starts off fine but after a few minutes runs very slowly. any ideas what may be causing this?
    Problem Solver:
  • 8 Answers
First check the metal screen inside the fitting that connects to the pool wall. Make sure it is clean. If there is no inline screen on the feed hose then the jets inside the pool cleaner could be clogging. If there is a screen that keeps getting clogged with debris(like every couple days) then there is a problem with your pool filter or multiport valve that is allowing dirt to pass into the pool cleaner and the pool. Also it could be the back-up valve hanging up(due to a bad bearing or bushing) The back-up valve is the large canister on the feed hose about 3-6 feet above the cleaner. Check for holes in the feed hose and in the cleaner tail.
Posted on Aug 15, 2010
RE LK 3504 (35 hp 4 wheel drive Tractor starts, runs 5=10 minutes under load, then slowly fades away running slower and slower until it stops. Restarts in 15 min, same result
Here is an idea.
It sort of sounds like there is a blockage after a while in the gas tank.
If there were sediment in the bottom of the gas tank, it would start and run fine sitting still.
However, when driving it, it would be a matter of a few minutes until the sloshing of the fuel would cause the sediment to mix in with the fuel, and clog the filter screen in the fuel tank.
When it stops, the sediment would settle back down, and in 15 - 20 minutes, it would be clear again.
God bless your efforts.
May 08, 2017 | Cars & Trucks
I have 07 ZX6R No mods,starts fine runs fine,cruises fine. Nail the throttle at any rpm,any gear and bogs. let off and just cruises. bike sat for 4 years and just started riding few months ago, been f
probably old gas or condensation built up in carb or injectors.if carbureated drain float bowl & if you still have old gas in it drain tank close drain screw/bolt refill with premium fuel add fuel cleaner like b12 chemtool or seafoam(7-10$) to a fresh tank of gas...sometimes i just add the b12 chemtool (3-5$)and run it a few miles and it snaps right back to new!
Jan 08, 2014 | kawasaki ZX-6R Motorcycles
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
Car idles rough upon starting then smooths out but sensor light is on. Replaced oxygen sensor 2 yrs ago. Any idea what sensor it could be?.
Maybe your coilpack? The humidity isnt good for old coil pack! after few minutes the heat of the engine dry it and run better
Jan 12, 2013 | 2002 Ford Taurus
Put radiator in and its still running hot. i figure its my thermostat but someone told me i need to bleed my thermostat. i never heard of that. can u tell me how to put the thermostat in and bleed it
most likely cause on a old vehicle like this is head gaskets ,they perish with old age and disintegrate ,i mean its 15 yrs old and only designed to operate for 10 yrs
May 28, 2011 | 1994 Acura Legend
Pentair legend 4 wheel cleaner - runs over its hose
check the white float on the cleaner. take it off and shake it, if it is full of water you will need to replace it. when they get water in them they make the cleaner heavy and it will tip of on its side.
Dec 20, 2009 | Pentair White/Gray Legend Platinum...
Slow running, constant 'not responding'
Since your purchase just occurred, pack it up and return it to the store. It doesn't appear to be operating properly at all, and you certainly would not want to start to repair it yourself as that would void the warranty. Return it and get another one which makes you happy...afterall you will have it for a long time. Regards, Joe
Nov 13, 2009 | Advent Netbook
2004 rmz 250 wont kickstart, but will push-start
Kick starting is sensitive to fresh fuel. Tank should be completely drained
May 23, 2009 | 2005 Suzuki RM-Z 250
Jeep will start but not idle when it's cold out
You have a cold start injector. It basically primes the fuel into the engine.
It`s like the old type `choke` systems.
Get it checked at an auto electricians.
Jan 26, 2009 | 2001 Jeep Cherokee
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
231 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
