Question about Nintendo Wii Console
The wii wont turn off and the light stays green
When i go to turn my wii off it wont turn off and the light that is suppose to turn from green to red , just stays green , the only way to turn it off is to unplug it from the back
  • 1 more comment
  • shaana Apr 08, 2008
    please let me know if you can help
  • Anonymous Jun 08, 2008
    yea my wii wont turn off too i dont know what to do maybe i should bring it back
  • shellymad1 Mar 29, 2009
    When I turn my wii console off, the light goes from green to a orangy red. In the end I had to pull the plug out. I have a charger to recharge the remotes which is attached to the wii and u have to leave the wii on. Idon't know if that has something to do with it.
Hold the power button on the console for 4 seconds, it should override everything keeping it on and the light will turn red. If this doesn't work sorry, thats all I know.
Posted on Mar 29, 2009
Try pressin it of with u hand held controler
Posted on Apr 08, 2008
  • 26 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
2008
Posted on Apr 03, 2009
SOURCE:
Wii has no power whatsoever going in
The button has to be pressed until you see the light come on try using the wimote power button on the upper left corner hold it until you see the light if its yellow its in standby if its green its on you should see the disk entry area turn blue a sec when it comes on. Then it should be green on the power light if no lights in just a couple or 3 seconds holding it down you may have 2 bad wii's in a row. If you take it back ask them if they have a test model on the floor and tell them to show you exactly how it works to power on and off.
Dec 02, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Wii is turned off with the red light on. Then when I turn it back on or load or eject a disc it turns green (like its suppose to) but there is no sound or video. the plugins are connected properly and in...
my suggestion is you can check once again the connections made in ur nintendo wii........and check whether u pluged corectly...................if the problem persists, you can easily fix this by using repair guide available on net...it will help you to fix this problem.....................
thank you........
all the best..................
click here to download
Dec 10, 2010 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
How do i restart my wii?
wii wont turn on has red light till you turn it on 1 green flash then cuts off . have to un plug and plug back in to get red light back on
Mar 04, 2010 | Nintendo Wii Console
My wii won't turn on
aqwtr-31
Jun 19, 2009 | Nintendo Wii Console
Slot Light
The disk slot comes on briefly when:
-You turn the power on
-You put a disk in or take one out
And it pulses when you have a new message on your Wii message board. It does not stay lit while the Wii is on.
Jan 17, 2008 | Nintendo Wii Console
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Dec 11, 2007 | Nintendo Wii Console
Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Nintendo Wii Console Logo
412 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
