Question about Dell E151FPp 15" TFT LCD Flat Panel Monitor
I have a 2003 Dell E151 FPb monitor that has been working fine on the 2003 Dell tower it's been connected to. I've just bought a new slimline HP and when I connect it, and turn on the monitor it goes green, then immediately yellow and the screen is black. If I push one of the other buttons on the monitor the screen says it's in power saver mode and to push any button on the keyboard. When I push a button, the screen just stays black and the light remains yellow. I'm not a techy and won't be taking apart the monitor. Is there any other solution other than getting a new monitor?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This issue is maybe due to loose connections from power board to the main board. Make sure that the capacitors on main board are not swollen. Also let me know what all boards and wires you have checked. Also, this can be a backlight issue and you can open the monitor and start checking the power board which is the board where power cord/plugs goes in as it seems you have checked everything else out. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 31, 2010
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
I'm having display issues on hp slimline s3120n w/Vista. When the PC boots up, the monitor momentarily lights up, then goes into standby mode. I attempted resetting the BIOS following the steps on HPs...
its ok just POST TO HP PC or HP Desktop, with tag data.
for sure fixya does not have all 10,000 HP PC's listed nor will it ever.
H3LL even HP dont. (shock)
a desktop PC, (easy to fix , them all) no magic and ATX spec.
standards in play.
why not do the tests in the correct order.?
and do not put other HDD os in to your box, or the reverse.
that will not work.
first off the screen is black.
so you go in to BIOS, does it work and stay working there.??
that is first no the HDD, we play with OS later.
make the screen work first
see that VGA jack on rear of PC
try a different screen see if you can get to BIOS and hold there for say 5minutes, or more?
if that fails ?
this is an Emachine, with no video card, (or was added later,did you look>)
all Emachines, if you add at Video card, you must turn off the on MOBO GPU chip 6150LE
or it will get very confused. (which to use)
only you know if rear side, has x2 ,15pin VGA ports on the rear
if only one there, then its lock box stock, ORIGIONAL.
it only has 1 PCI-express 16x slot for added VGAG card.
if present remove it, and use the normal JACK
the goal is to get one of the 2 VGA jacks to work
that take owning 2 monitors, lacking a second, barrow one.
BIOS work now?
http://support.hp.com/doc-images/234/c00910084.jpg
BIOS hot keys (F1, F9,f10, esc, delete key)
the book on your machine tells you which hot keys work on your PC. and must be known by you or diagnosis goes to hair pulling.
http://jeepdied.com/look/puters/dead-screen.html
not yours but will look same with your exact model
try to know there are many sub models on all HP systems.
Mar 17, 2017 | HP S3120N Pavilion Slimline Desktop...
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
I have had problems with communication between the tower and the monitor. I recently bought a Dell flat screen monitor. The monitor worked for about two months, now when it is turned on, it immediately...
Sorry it IS the monitor this is a common problem, unfortunately, this is evidenced by the fact it still didn't work when connected to another machine,regardless of lack or message. Do a warranty claim.
Mar 05, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I bought the hp slimline s3707c a few months ago and I love it! But due to me being a huge gamer I needed to upgrade my Vid Card. The new card doesn't fit in the tower so I bought a bigger tower and was...
My best suggestion is to get a professional installer to do it for you.
If you want to do it yourself.
  1. take the top of (make sure to ground yourself) and DONT work on carpet if possible. Static is bad!
  2. the HP is nice in the way that it has sliding internal features. So some of the chasis will slide out of the way. Take advantage of this.
  3. BEFORE you take ANYTHING APART make sure the mounting screws of the motherboard line up with the mounting area of your newly bought CASE. Also, make sure output on powersupply on new case comparable to your existing one, and that connector wll fit your MotherBoard.
  4. disconnect all power supply wires
  5. take out Power supply which will give you more room
  6. disconnect ribbon cables (or SATA), remove them.
  7. unscrew mounting screws on motherboard and put it in your new case. Make sure MotherBoard does NOT ground to your case (IE it should not wiggle around) and be put in securely
  8. remove peripherals from your old case and put in your new case (HDD, CDROM, etc.)
  9. connect power supply cables, then ribbon cables (or SATA if so)
  10. Put case together and connect wires in back (Monitor, keboard, etc.)
  11. Your are done, Congratulations!
Nov 09, 2009 | Computers & Internet
The PC time clock is gaining time!
Yes it is, however, the Vostro 200ST and MT series are the same board its a 10cent battery, they sell them at a camera store
Jul 16, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Dell E151FPp 15" TFT LCD Flat Panel Monitor Logo
71 people viewed this question
Alun Cox
