Question about Fisher and Paykel GWL11 Top Load Washer
High pitched noise
Beginning stages there is a high pitched noise coming from the washing machine. Hardly no water or has not filled to its compacity.
    Problem Solver:
  • 3 Answers
This is a water pump about to blow, or a clogged filter or hose. The fact that you hear it immediately, and limited water level is involved, it's pretty much your bingo.
After turning off the water supply, unscrew the garden hose-like attachments for hot and cold water intake. There is sometimes a small filter right there where the water enters. If they're clogged, clean em.
Take the hoses and run them through an outside plug to make sure they aren't clogged with back flowed dirt from the filter and hard water.
If it still won't fill, you'll need to test the pump.
each machine is different, but if you follow the hoses from where your hoses enter the machine, you should be able to unscrew them at the other end.
Stick them in a deep bucket then turn on the machine and see what the pump does. Is the noise coming from it? (service or replace). Does water gush out of the pump into the bucket? (clean all hoses and filters, buy some machine grease and lube all the moving parts, including opening the water pump and giving it a generous amount of grease.
Put it all back and your squeal will one way or another be gone and you'll have plenty of water
Posted on Jun 01, 2010
LG washer high pitch noise when water enters at beginning of cycle
Two possibilities: the water is coming in under pressure through a solenoid valve that is not fully open or the pressure pump is whining on its bearings.
Jan 22, 2013 | LG WT5170V 4.7 cu ft High Efficiency Top...
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
When my kenmore oasis he washing machine starts pumping water into the tub, it makes a high pitched noise. (The pump maybe) It only happens when it it filling, either at the beginning or during rinse...
Thanks for choosing FixYa and welcome. Darren, you need to get to the pump and check the belt. See if it is slipping or you may have a pulley sticking. It may be the pump itself. More then liekly, it is the pump grinding.
Apr 25, 2011 | Kitchen Ranges
Our machine functions correctly, but makes a high pitched -
need a new fill valve that what it sounds like check to see if your water is turned all the way on that can do it to.. and yes you can get parts for it
Jan 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LE code on lg washmachine
The LE error code means that you have a motor problem.  The high pitched noise means that the motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to replace the sensor.
Jun 06, 2008 | LG WM1814CW Front Load Washer
Noisy Water Fill
try closing your water valve a little, see of that reduces noise level and even off. you wanna see if its your plumbing or the machines valve
Feb 24, 2008 | Fisher and Paykel GWL11 Top Load Washer
High pitched noise
The inlet valve is faulty and needs to be replaced.
Nov 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
216 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
