Question about Canon Rebel XT / EOS 350D Digital Camera
Auto focus isn't working
When I am ready to take a picture and press the shutter in slightly to focus it doesn't kick in... this camera is only a year old and I have never had a problem with it. Please help!!
  • Darren Perlmutter
    Darren Perlmutter May 11, 2010
    Are you sure the camera is in autofocus mode?
    Problem Solver:
  • 15 Answers
Check the lens. If the switch is set to MF then it is in Manual Focus.
Another cause could be custom function 4 - try setting this to 0 for the default
Posted on Jul 09, 2008
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
Apr 23, 2014 | Fuji Finepix S1500 10.0 Megapixel 12x...
Camera wont snap picture
As long as the orange light is on, the camera is not ready to make a picture. The focus area, should become green, to tell you the camera is in focus. Then you can press the shutter release button complete. Check the settings of the camera, and put it in automatic. When you put it in one of the manual modes pipe P M S or A, the camera will not take a picture when there is not enough lift or something else you did not take in account.
If the camera keeps this way, unless you switched to auto, it could be there is something going on. but let me know it auto des not work.
Jan 27, 2014 | Nikon COOLPIX L810
Brand new 2980 series fuji digital camera but photos are slightly blurred
Most digital cameras have an auto focus function, to activate the auto focus press the shutter button half way down until the you get a green light or indicator then press the shutter button the rest of the way down.
Jul 07, 2012 | Fuji Cameras
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
How to take clear pictures
Hello.
Considering your camera is in good working order go to the menu and look fot the option to turn on sounds if they aren't already on.
With your camera set to auto, aim it at your subject and partially press the shutter button. At this point you may see the image on your screen change from blurry to clear as the camera auto focuses. Usually a green light will appear on the screen and sometimes a sound will signal you that the camera is focused and ready to shoot.
You must wait for the camera to focus and give you a signal before pressing the shutter button fully. Give it a try and practice with different situations and backgrounds as focus time will vary between sceens.
Hope this helps. Dale
Dec 21, 2011 | Cameras
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
Canon G9 digital camera
There are two stages to the shutter release. The first stage is the focus stage pressed half way down and the second stage is the actual shutter release. Always press the shutter half way to get the camera focused first then press all the way down when the camera is ready to take the shot. Check to see how the settings are with regard to how it focuses (9-point, face recognition, etc). When the camera focuses you should get a green box or multiple green boxes depending on your settings. That tells you the camera is ready to take the picture. Pressing the shutter all the way down at once from the beginning will cause the pause you describe since the camera has to first focus then shoot the picture. Depending on the subject or subjects the camera may take a second or two longer to focus. With good lighting my G9 focuses pretty fast. Hope this helped.
Aug 31, 2008 | Canon PowerShot G9 Digital Camera
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
