Question about RCA P46812BL 46" Rear Projection Television
Dual Picture The picture is great for about 10 minutes and then it looks like a double exposure or a 3D show. If we cut off the TV for a few minutes, it corrects itself. But, after being on another 10 minutes the problem arises again. What should I do?
  • Glorykid Apr 08, 2008
    The picture is great for about 10 minutes and then it looks like a double exposure or a 3D show. If we cut off the TV for a few minutes, it corrects itself. But, after being on another 10 minutes the problem arises again. What should I do? My chassis # is PTK195AA
  • RCA Master
  • 8,617 Answers
Your covergence power supply needs new ICs. Let me know the chassis number off the rear of your set and I will post the correct IC that you need along with a link where you can get a replacement with free installation instructions and free tech support
Posted on Apr 08, 2008
82" Mitsubishi DLP tv Picture Blinks every few minutes
your Lamp is on the Way out. You will need to replace this in the Next 4 months, This is the First sign of the Lamp failure. How old is the TV?
Nov 10, 2013 | Mitsubishi WD82738 82" inch 3D Ready DLP...
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When the tv is first turned on the picture is great. After about 5-10 minutes the picture looks like a 3 D movie when you're not wearing the proper glasses. Sometimes turning it off for 10 minutes and...
the 3d effect is caused by a mis alignment of the tree tubes you probably have a broken FRAME holding the tubes in place so that HEAT or VIBRATION can move them and the alingment is off dont forget you have one tube for RED one for GREEN and the other for BLUE if they are not aligned properly they can look like a 3d pcture without 3d glasses ha! sorry for the bad grammer...
Jan 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
Bad picture
Ur convergence is dead,U know how to solder?Buy a convergence kit.Use what in that kit.Websites have it.Tv Repair World.com,Ebay.com.
Oct 14, 2009 | Televison & Video
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Forget how to take double pictures.
Hey xplaur,
To take a multiexposure photograph you should first expose the film, and then push the multiexposure button which is on the front of the camera on the top left when you are looking at the front of the camera. After you press this button advance the winding lever to set the shutter, and since the multiexposure button was pressed this shouldn't wind the film to the next frame. Now take your second exposure, and if you want to make another exposure on the same frame repeat the process. Keep in mind that every time you expose a single frame after the initial exposure you will be doubling the exposure on the frame. I usually under expose each exposure by one third on a double exposed frame. If you do more than two exposures I would underexpose each exposure by even more. Multi exposures are fun but tricky, and I would suggest you experiment and have fun with it. I will also say that black and white film is much more controllable and forgiving when it comes to this than color film. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 31, 2008 | Vivitar V3800N 35mm SLR Camera
On cold start,picture flashes double exposure
CRT's ok.......Convergence issue....replace STK IC's
Part # STK392-110 upgrade to STK394-160E # CZ 01341.......T.
Nov 03, 2007 | Toshiba 50H72 50" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
