Question about LG WM-1832C Front Load Washer
I neet o replace drain pump on a LG wm1832cw model
I neet to replace drain pump on a LG wm1832cw model front load washing machine. How do I get the panels off to get to the part? The drain pump is located near the front, lower left of the machine. Thank you
Its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Posted on Jul 10, 2010
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
i took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Jul 08, 2008 | LG WM-1832C Front Load Washer
LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Jun 17, 2008 | LG WM-1832C Front Load Washer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
770 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
