Question about Craftsman 24 Hp 48" Deck Yard Tractor
Take off Blades nuts turn witch to take off
Take off Blades. Nuts turn witch to take off.
Nick
    Problem Solver:
  • 11 Answers
Counter clockwise
Posted on May 31, 2010
What is the correct way to Install New Blades on John Deere G100 with 54"cutting deck
Do Ray:
I pull my machine up so the front tires are on a ramp. make sure the key is out of the ignition. Raise the deck to its top position (every little bit of room to work helps!) I think that the spindle nuts are 1 inch. lodge a two-by-four piece of wood between the tip of the blade that you are removing and the blade deck and remove the nut at the bottom of the blade (make sure you are turning your wrench in the correct direction!) It will take a two-grunt pull to loosen the nut. The blade should fall off when the nut is loosened. Make sure to not put the new blade on upside down! (Use the other two blades for reference). Repeat for the other two blades. Make sure that the blade retention nuts are Very Tight.
Jun 15, 2015 | John Deere Garden
I got alot of vibration when i engage the blades on my 44 inc swisher rough cutter
I had the same problem twice. The first time happened when the blades were not swinging freely because they got gummed up with grass. So make sure your blades pivot easily.
The second time happened when the nuts came loose from the blade driver (the part underneath the deck that the large bolt goes through to hold on the blade assembly). I had taken the Swisher to a small engine repair place for servicing. They removed the blade assembly to sharpen the blades while it was there but put the old lock nuts back on without using any Locktight, so the nuts started to come off while I was cutting. Unfortunately, I did not notice this until after the blade driver got very loose and then got reamed out by the wobbling of the large blade assembly bolt. I had to replace the blade driver and its bolts and nuts.
May 09, 2012 | Swisher 44-Inch 12.5 HP Trailcutter...
How do I change out the blades on a john deere 155C 48
Jack up the mower so you can see and reach the blades.
Loosen the bolts/nuts holding the old blades. Remove. Install the new blades. Tighten the bolts/nuts, finished.
Apr 22, 2012 | Garden
PLEASE PROVIDE INSTRUCTIONS FOR INSTALLING AND REMOVING BLADES CHEERS DENIS
There are two nuts up by the blade that will be removed to get blade off also there is a small screw next to the blade itself on the opposite side. You must loosen 2 big nuts then back this small screw off a few turns will be inside a small hole near blade. Once blade chain is loose take nuts off drop blade replace do everything now in reverse.
May 06, 2011 | Garden
Are the nuts holding on the blades reverse threaded?
If a blade, when viewed from above, rotates clockwise, it will have right-handed threads. This is because the shaft is turning to the right, and the resistance imparted on the blade will tend to tighten a right-handed fastener. If a blade rotates counter-clockwise it will have a left-handed fastener. I don't know this mower, but this is a universal thing.
Apr 23, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Witch way does the nut turn on the harmonic ballancer nut
when it come to honda all nuts and bolts are lefty loosy righty tighty
Oct 24, 2009 | 1996 Honda Accord
I cant get the nuts off the blades on my cub cadet do you turn them l or r
Not sure on your particular mower but most all mowers are left hand threads so you would loosen like you are tightening normally. I hope that is clear to you. lol
Sep 11, 2009 | Classic Accessories Garden
Remove cutting blade
take the blade disc off the mower, you should have the nuts on the top of the disc for the blades, put the disc on the ground and remove the nuts on the blades.
Replace the blades with the new ones and fit the disc back under the mower
Apr 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Nut problem
This might be a long shot, but have you tried turning the nut the opposite way? The nut will probably have to be turned the opposite way of the rotation of the blades. This might be the "wrong way". Some nuts are opposite to keep things from comming off. Like the nuts on the right side of my remote car to keep the wheels from falling off.
Jun 17, 2007 | Bionaire BSF1731RC Stand (Pedestal) Fan
Craftsman 24 Hp 48" Deck Yard Tractor Logo
64 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
