Question about Samsung TV Remote Control
BROKEN IN TROBLE
The remote is olny responding to the TV section and the remote top that respondes seems broken and now olny works with TV. Is there anyway to FIX it easly and without having to buy a new one. Or can a member of Direct TV replace it? HELP!!!
Contact me as soon as possible at [email protected]
Please report back SOON!!!!!
    Problem Solver:
  • 14 Answers
If it is a direct tv remote they will replace it for a minimal charge. If it is a remote from the tv, the manafacturer will replace it within a year and if you bought an extended warrantyfrom a store most will replace it free of charge. Except circuit city. They wont help you not one bit
Posted on May 31, 2008
SOURCE:
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Tv not responding to remote
the remote may have dropped and there are 2 possibilities of fault.
1-acrystal which gives accurate frequecy was broken
2- the infrared sender led was burned or the printed cicuit connection for this IR led is broken
Jan 28, 2013 | Sonic Impact Technologies Sonic Impact...
The remote is compatible to your tv? or the infrared is broken.
Oct 21, 2012 | Samsung Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
My car alarm key remote is not working. alarm not responding to remote. is remote broken
This might sound stupid, but have you tried first replacing battery in remote, this could cause this instantly, just like a TV remote. First try that. Hope that solves it right away.
May 15, 2011 | APS787 Prestige Remote Start and Security...
I was given an rca hdtv model L32wd12 by my boyfriend he had never used it at his house but the person he bought it off of used it. I can not get the tv to do anything but turn on to a blue screen and turn...
I am not an expert but I would guess the tv is broken.
The set might need retuning to receive programmes from an aerial but that would necessitate using the remote to select the main menu. If the menu cannot be selected it is a big clue...
When a signal is injected through an HDMI port or similar the tv should respond automatically. If it doesn't respond I believe that is another clue the tv is broken.
You could make sure by downloading an instruction manual just to be certain you are doing everything right.
Sep 26, 2017 | RCA L32WD12 32 in. LCD HDTV
BROKEN IN TROBLE
Hi Jasmine - Let me know if it says RC32 in the top left of your remote. If so, just to the right of that, there is a switch that slides left and right. This chooses which device you are currently controlling with your remote. To control your Directv, just slide the switch all the way to the left. You probably have the switch slid all the way to the right. This for the TV. The two in the middle are for other devices. If this solves your problem PLEASE rate this as fixed. If you need more help just a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Apr 08, 2008 | Toshiba Satellite A105 Notebook
SHARP T.V. not responding to remote, but remote isn't broken
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Same thing happened to my Sharp 29 inch. Stopped responding to original remote the first time, but a universal worked fine. Eventually it stopped responding too all universal remotes. The remotes are good, they work with my VCR, DVD player, and Receiver. It's a nice TV, but having to get up and adjust the volume every commercial break got old a few decades ago! If anyone has any other possible solutions aside from getting the sensor replaced...would be great to hear it.
Oct 29, 2007 | Sharp 32C-240 32" TV
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Samsung TV Remote Control Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
