HP printer HP PSC 1500 SN: MY596D11PB Model #: Q5888A Copy mechanism works find. Printing from computer sometimes does not print; lights flash on and off rapidly. Pressing the cancel/resume button does not help. By pressing the power button it will reset and sometimes will print ok the next time.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 31, 2010
  • 19 more comments
  • rkcrump May 31, 2010
    I took the ink cartridges out. Now, how do I access the print heads to clean them?
  • Rylee Smith
    Rylee Smith May 31, 2010
    Print head is where the cartridges sit, once you have taken the cartridges out you can start cleaning the area.
    The copper areas look clean. I cleaned some black goop out from the area where the ink cartridges sit. How do I access the printer heads to clean them? Do the printer heads come out?
  • Rylee Smith
    No, there is no need to take out anything. If you have already cleaned everything then try to place everything back and try to print. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • rkcrump Jun 04, 2010
    I have done everything you suggested. The printer worked ok for a few days. Today, the same problem as reappeared. What is your next suggestion?
  • Rylee Smith
    Rylee Smith Jun 04, 2010
    As cleaning the print head worked so it seems that the print head is going bad and should be replaced.
  • rkcrump Jun 05, 2010
    We removed the ink cartridges and cleaned the area like you recommended last Monday. It worked for a few days. Now you recommend purchasing a new print head. Questions: How do you remove the print head? What is the model number of the print head? The user guide for this printer does not show where the print head is located or how it can me removed. I could not find a print head listed under HP on-line for this printer.
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    The cost to replace print head is usually around $75 in which you can buy a new one. Before doing that you can try to download the printer drivers from this link.
    How would it help to install the print drivers, because sometimes it prints fine and sometimes not. I thought that once you installed the print drivers you did not need to install them again. Where do I go to purchase a print head? HP said that no parts are available for this printer. Is that true? Is this printer worth spending $75.00 for a print head? Where do I purchase a print head?
  • Rylee Smith
    Over time
    the printer drivers may get corrupted and you’ll need to uninstall and
    reinstall these to resolve the issue. You can download and install the drivers
    from the ling provided earlier. If still the issue is not resolved only then I’ll
    suggest changing the print head. Print head are just behind where the
    cartridges sit and are available with HP as given on the link and it costs
    around $40 each and you can buy them online. It is worth replacing one or all
    print heads if required.
    Thanks
    Rylee
  • Rylee Smith
  • rkcrump Jun 06, 2010
    I went to the HP site. There are no instructions on how to uninstall current drivers. There are only instructions on how to install drivers. How do you uninstall?
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    OK, install the new one and it'll update the older one, also check the link that I posted earlier for print heads.
    I downloaded the printer driver software as you recommended from the HP link you forwarded. The download was completed. However, the installation window never did open with further instructions for completing this process, as it said would happen in the HP installation instructions.
  • Rylee Smith
    It wont open automatically you'll need to run the installation process from the file that you have downloaded...as I said earlier and this is not necessary that this will work. It is the print head that is going bad which is not allowing the printer to print intermittently, so its better to get it replaced. If you are unable to get it online you can get it through any of the repair shops. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    One of your responses on June 5 was to try downloading the print driver BEFORE replacing the print heads.
    We don't understand how to get to the folder you have referenced to.
  • Rylee Smith
    Please click on this link for print heads. I understand however, from what you have described till now dont think that it should really resolve the issue as the only way is to replace the print head or buy a new printer for as low as $50. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    I clicked on the web site that you suggested. Which print head is for my printer? There are several listed.
  • Rylee Smith
    As I said earlier you can call HP and check with them before buying it...
    What is the toll free telephone number? Which department do I ask for?
  • Rylee Smith
    You can contact them at 800-752-0900 or click on this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
How do i change scanner light bulb on hp psc 1205 printer
Most of the time the light bar is not the problem when it comes to print quality issues. Those are typically ink cartridge or printhead issues. Try printing a self test page and compare.
Dec 19, 2014 | HP PSC 1205 InkJet Printer
Can't print from computer
Reinstall the printer drivers. (completely remove the old ones first)
Try new drivers from HPs website if need be.
Check the print queue in control panel>printers to make sure nothing is lying in the print queue and blocking your printing.
Make sure that you are printing to the correct printer in the "print" dialogue box that pops up when you go file>print. Sometimes this can revert to "microsoft document printing" or somesuchand just save a file on your hard drive instead of printing (in techie speak, printing does not necessarily mean print out on a bit of paper). Or may the "Print" dialogue box wrongly is pointed at another/old printer that still has drivers installed on your pc when it pops up, check before clicking the "ok" button..
If not, try a new cable, if not, call HP.
Feb 05, 2010 | HP PSC 2175 All-In-One InkJet Printer
I can scan, BUT I can't print. HP PSC 1500 windows 7
Go to control panel and check the printer status, Unplug the USB cable than right click on printer icon and click on delete. Once you do that make sure printer icon should be gone. Than restart the computer. Once computer is Up than connect the USB cable of printer and make sure while doing that , the printer should be powered on. After that printer icon will again reappear in contro panel.
Try printing, it should work
Jul 22, 2009 | HP PSC 1510 All-In-One InkJet Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
HP psc 1500 all in one series copier won't print just prints line
hi i/am not computer smart i'am trying to connect printer to computer that;s my trouble?
Mar 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1410 ALL-IN-ONE Printer-Scanner-Copier
My HP PSC 1410 is not printing and it seems not to have any communication with my computer.
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printer
i cNNOT FIND THE HPPSC1510DRIVER WHEN I DONLOADED THE C240 IS COMING WHY
Sep 15, 2008 | HP PSC 1510 All-In-One InkJet Printer
Need to install printer HP PSC 1500 all-in- One series
i lost the software of psc 1500 all-in-one can you help me?
Jun 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Vista compatability download for my HP PSC 1500 all-in-one series
Yes the download are the same for all the models..this is the link to download the driver for vista...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&softwareitem=mp-37852-1&os=219&product=428800&
I hope this helps
**Please rate accordingly**
Thank You
Computerrep
Jan 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
53 people viewed this question
jasbo
jasbo
