Question about Breadman TR2200C Ultimate Bread Maker
The bread pan leaks dough and the rubber "stopper" came out as I cleaned the pan.(I had used the "dough" cycle) This happened before and I had to get a pan but I don't find that part on the site. HELP Nancy@fibernetcc.com
  • 1,284 Answers
Hi, your best bet would be to look on eBay. Perhaps you can get one there, but they are kinda expensive if you can find one.
Take care
Posted on May 31, 2010
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
Is there anything I can do?
I don't know about your specific model, but in most bread makers there is a removable paddle that goes in the bottom of the bread pan after you put that in the machine. The paddle usually has a flattened side on the hole which slides on to the post sticking up from the bottom of the machine. If you look at the post straight down from above it should be D shaped. The usual procedure is to put the pan in the machine, install the paddle, and then add your ingredients. Assuming you are doing this and it is still not working, trying running it through a mix only cycle (like for pizza dough) with the machine empty to see if the paddle is engaging and spinning properly. If it is not, contact the manufacturer for assistance.
Aug 08, 2014 | West Bend 41053 Bread & Dough Maker
My Emiril bread pan is leaking grease also, there needs to be a safety recall this pan has hardlry been used . Where can you get another one and how long before the new one leaks grease. Buying new ones...
i don't have an Emiril bread pan but i do know that the leakage won't be oil but dough that has leaked through the seal around the spindle. when it comes back up it is dirty. this is caused by the friction as the spindle rotates. it is all down to wear and tear, so i wouldn't worry too much about it happening if you buy a knew breadmaker. good luck . jackie A
Jan 29, 2013 | Kitchen Appliances - Others
Bread dough spills over the side of the pan and burns on the element
do not the instruction say that when the dough is made it has to be in the fridge to allow it to rise before putting into tray to cook
Jun 08, 2017 | Kitchen Appliances - Others
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
Bread pan is stuck I can't get it out
Try adding a recipe of ingredients, and run on 'dough" cycle.
May 31, 2010 | Breadman TR875 Bread Maker
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
