Your fob or key isn't being recognized. It may need replacement. If it's not the key or fob, it's probably the radio (radios often control things like anti-theft or keyless entry). I recommend talking to a car locksmith.
sounds like fuel pump is ready to fail. first check and or change fuel filter. if truck still shuts off then time to test fuel pump. first see if it is running by taking off gas cap and turn on key just one notch short of starting truck. if you hear a hum then your pump is working. but then you may have low pressure. if so then your fuel pump needs replaced. I just did this. its about a 4-6 hour job. go to youtube they have a good step by step video on how to do. good luck
I hate to tell you this, but all of the components you have just change will not do a thing for the anti-theft light. The vehicles security system has been activated, and that is what is not allowing the vehicle to start. The only way to diagnose what is causing this is to have a scan device capable of Body Control Module communication.
There is a problem with the ABS (Anti-Lock Brakes). Unless you have the knowledge to diagnose and repair this problem I suggest you seek help from a trusted mechanic or your Volvo dealer. Your ABS may not be working correctly but your normal brakes will still work.
One of the sensors for the anti-theft is loose or not connected properly hense its shutting down the engine. Any service center should be able to identify it with the help of a computer connected to it....sodeep
