Question about Weather King 10AJA6001AH Air Conditioner
Where to locate evaporater coils - Weather King 10AJA6001AH Air Conditioner
  • 146 Answers
Evap coil is on top of your furnace. sometimes it in the duct work. just follow the lines from the condenising unit. their will be two copper and one pvc.
Posted on May 31, 2010
Location of orifice tube on 1996 xj6 jaguar
its in the high pressure side of the a/c system in the evaporater or the pipe from the compressor to the evaporater
Jul 05, 2017 | Jaguar Cars & Trucks
Refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Aug 13, 2007 | Sub-Zero 632 / S
I have a frost free hotpoint and theres ice on the freezer door and the food inside it what could this be and how,do i fix it
Hallo
Frost free means there is an evaporater coil behind the backplate of the inside of your fridge.
How it works is a fan is for example installed in the lower back of your fridge and the evaporater above the fan covered by a plastic cover/steel plate and now the fan is pulling the warm air from the top over the evaporater ( the evaporater is then pulling the warm air into the evaporater without increasing the temperature of the evaporater) and dehumidify at the same time and blowing the cold air out a the bottom of the backplate while the warm air moving to the top where it could repeatedly repeat this action.
Tell me what is the condition of your freezers door seal? It can only be caused by humidity getting in so it mean the door is not sealing 100%.
Regards
Jun 09, 2016 | Hotpoint Refrigerators
How does ac evaporative coil with piston work?
the evaporater coil's piston acts as a orfice. the size of the piston hole allows a certain amount of refrigerant through at design pressure. it produces a designed temperture drop at designed cfm of air across it.
Jun 19, 2014 | Goodman Heating & Cooling
Overflowing
These units must be removed and chemically cleaned annually or the channels along the units bottom that allow the condensation to migrate to the outdoor coil and be slung onto the coil via fan blade thus evaporated,sub cooing the refrigerant as it does so, cannot work, if the units not level or if the evaporater coils dirty the condensation cannot drain either..
Oct 09, 2013 | Danby Heating & Cooling
Frosted evaporater coil whirlpool refrig.
This tip i wrote previously covers what to check when the Evap. coil is frosted
http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
one of the components listed there will be the problem
GENE
Aug 26, 2011 | Whirlpool Refrigerators
The coil in the freezer is freezing up no air flo
either defrost timer, t-stat or heater is bad. either way it is worth repairing.
Feb 12, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Location of cabin air filter? How to replace cabin air filter?
check behind glove box at top of black coil housing, look for door/cover
Sep 27, 2009 | 2007 Honda Accord Sedan
Refrigerator stopped cooling
My guess is that you have a defective defrost timer.
Most refrigerator operate on a 24-hour self-defrost cycle. It takes about 1/2 hour to complete. During that time, a timer shuts down the compressor, turns on a heater imbedded or surrounding the cooling coils, and melts any ice that has formed.
It then turns the refrigerator back on to resume its normal cycle. This happens once every 24 hours.
You might have a bad heater coil, but far more likely is the defrost timer. It's usually at the bottom of the refrigerator... A small black phonelic box with wires going into it.
While you've got the inside disassembled, you might want to check the heating coil, but my guess is that it's good. More often the not, the culprit is the self-defrost timer which is usually located under the refrigerator.
Newer models have solid state controls and sometimes have the defrost timer integrated into the circuit board, but some still have a separate defrost timer. I'd bet my reputation that's your problem.
Aug 21, 2009 | Refrigerators
Check engine light on, engine running rough
evaporator is part of the fuel system, missfiring could be spark plug or bad coil
Mar 26, 2009 | 2001 Mercury Cougar
Weather King 10AJA6001AH Air Conditioner Logo
47 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
