Question about Amana A8RXNGMWE (176 cu ft) Top Freezer Refrigerator
Water is leaking from my freezer. leaking down into the bottom of fridge then on floor
This problem can occur when both the freezer and fridge controls are set too high. This cuases the pipe between the top and bottom units to freeze up and the fridge does not cool down to the required temperature and also causes water to drip out of the bottom of the fridge. To solve this problem, switch off the appliance for a day to let the pipe un-freeze and re-set the controls to a lower number.
DJC
Posted on May 31, 2010
  • Amana Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerwater is leaking from my freezer - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 72 Answers
SOURCE: leaking water onto floor at front of refridgerator
could be a leaky water valve
Posted on Jun 11, 2009
  • 583 Answers
SOURCE: leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Posted on Jun 12, 2009
arikrom
  • 528 Answers
SOURCE: My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday .com good luck
Posted on Jan 03, 2010
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Water leaking from freezer and fridge
Need to see if the drain if frozen over. Will have to take back panel in freezer off to verify. This is usually the cause. If it is frozen over run hot water down drain until all ice is gone. If the defrost heater is close enough to the drain you can install what is called a heat probe that attaches to the heater and sticks down into the drain hole which helps prevent this problem.
Oct 06, 2007 | Candy CPCA240FFK Bottom Freezer...
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Amana A8RXNGMWE (176 cu ft) Top Freezer Refrigerator Logo
253 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
