Question about Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br
Our topflush toilet will nto stop running, once it is flushed. Theflapper seems secure. Not sure about the fill valve part.
    Top Expert:
  • 12,104 Answers
After flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
Posted on May 31, 2010
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
Toilet doesn't turn off after flush
The Kohler Cimarron is one of the most popular and reliable toilets out there. (My Favorite). However, depending on the hardness of the water and if you use cleaner tabs in the tank, these factors can lead to a malfunction.
The first thing you should do is hold the flapper (rubber seal inside the tank that releases the water down to the bowl) down with your hands for a few seconds after a flush and see if the toilet stops running. Sometimes the flapper doesn't seal properly therefore the fill valve keeps working non stop. Stopping the fill while holding the flapper down will confirm that your flapper needs to be changed.
If this doesn't work then try this....
The other common problem with a running toilet is with the fill valve itself. There is an attached float on the fill valve that goes up and down depending on the water level. Once the water level rises, it rises the float, and the float tells the fill valve to stop filling the tank. While the toilet is running (hissing), try raising the float all the way up with your hand and see if it stops. If it stops but not consistently with every attempt, then you will need to change the fill valve. I believe the Fluidmaster 400A is the replacement model.
Nov 23, 2010 | Kohler Cimarron Comfort Height elongated...
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
After each flush, the tank fills but the fill valve doesn't stop and the water keeps running into the toilet. How could I adjust the fill valve?
Usually the problem is dirt in the fill valve and not an adjustment problem...
depending on which valve you have it can be taken apart and cleaned out... just remember to turn off the water supply before taking the fill valve apart...
Jul 28, 2010 | Kohler Toilet - One Piece with Ingenium...
Dear sir/madam. when flushing toilet it takes a
Some water saver toilets are very problematic about not having enough water to thoroughly flush. Here are 2 things to look for:
First, after toilet stops running completely, check the water level. Most tanks will have a "full" line marked inside. If the water level is low, your fill valve will need to be adjusted.
Second, if the water level is fine, your "flapper" valve (very bottom of tank) may not be opening all the way. Watch valve as you flush the toilet. It should come up far enough to allow total unobstructive flow of water. If it isn't, adjust chain length until it does. Make sure there is a little slack left.
If neither of these solves your problem, you may have a partial clog that will need to be gotten out with a drain snake that can be purchased at any hardeware store.
Jun 08, 2010 | Home
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Logo
181 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
