Question about Singer 7462 Mechanical Sewing Machine
Top thread locks bottom thread bunches and machine makes noise
  • 40 Answers
Start with a deep clean and oil. check tensions, top and bottom-stitch should "lock" inside the fabric. make sure you use same thread on bobbin as on the machine. Check needle for nicks or bent. Make thread is threaded correctly, passing through upper tension plate. check tension plate(upper) for rust or lint.
Posted on Jun 01, 2010
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
My machine is noisy seems stiff and the thread is bunching underneath bobbin case seems loose
It may need a cleaning and lubrication to resolve the noise and stiffness.
as to the thread bunching on the bottom, try re-threading both the top thread and the bottom thread, if it persists, try a different bobbin, (the one your using may not be wound properly, it happens) If it still persists try a new needle. if all of this fails, take the machine to a reputable service facility, it usually helps to take a sample stitching to show them exactly what it's doing to you,
Good luck and happy sewing!
Aug 12, 2014 | Sewing Machines
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
Broken and bunched thread on back of fabric
try changing the needle
also try adjusting the top thread tension and see if that helps
make sure the top thread has not come off the thread take up lever
also the machine may need to be checked for a timing problem.
Nov 28, 2012 | Sewing Machines
Thread keeps on bunching up on the bottom side of the fabric
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
make sure the thread has not come off the thread take up lever
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
Thread bunching up on under side
try rethreading the machine top & bobbin
check to see if the thread has come off the thread take up lever
also make sure the needle & thread & fabric are compatable
Mar 10, 2012 | Sewing Machines
Thread is bunching up on bottom. I have cleaned the machine, am using Madiera thread, new needle. I have a quilters choice, and have never had a problem before. I am working with lace and batiste.
My thread is bunching up on bottom of fabric and loose on the top, not sure when I am embroidering on my Baby Lock Essante machine, it just started, why?
Feb 04, 2011 | Baby Lock Sewing Machines
Top thread bunches under the project and machine makes loud noises then finally stops
Take out all the thread and re thread from scratch. I suspect bad threading.
Dec 12, 2010 | Baby Lock Esante
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
162 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
