Question about Air Tools & Compressors
My air compressor won't compress more than 40 lbs what can I do?
  • 5,603 Answers
This is either a problem with the check valve (common problem) or with the compression release. The compression release is often a centrifugal device on large 5Hp types or part of the pressure switch on small pancake types. The valve should close while unit is running. For the check valve, broken springs or worn out valve seats are common. The check valve is usually where the pipe goes into the tank.
You don't say what model of compressor you have so can't give anymore details than this..
Posted on May 31, 2010
  • 8,404 Answers
Your compressor is worn or dirty or both. Disassemble the head and inspect it. Look for dirt in the reed valves ... look for excess sloppyness in the piston (worn rings)
You may be able to repair this, expect to pay $50.00 for a kit (you dont ID the unit so I cannot make a recommendation) ... It may be cheaper to replace the unit rather than have it repaired professionally.
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Compressor will only hold 20 lbs and looking for some troubleshooting ideas
First check for obvious air leaks:
1. The drain valve on the bottom of the tank.
2. The air hose, both end connectors and the length of the air hose.
3. The air pump, where the line comes out of the pump and where it goes into the tank.
A spray bottle with soapy water works well for this. Sprayed on these areas, look for bubbles indicating a leak. If the motor/air pump is hot make sure the bubbles are not from the solution boiling away.
If these check out, you may have a damaged valve plate or piston/cylinder assenbly. Damage to either will not let the pump move enough air to fill your tank. To check these you have to remove the pump head. The check valve(s) are on a plate directly under the head. Check that the reed(s) are not chipped, cracked or broken off. They have to be in perfect condition to seal the incoming and outgoing air holes so air can be compressed enough to fill the tank. If OK, check the piston and cylinder. They have to be in very good condition to compress the air also. Some times the ring(s) around the piston get damaged and won't seal to the cylinder well. If any of these are damaged you'll have to replace them to get a good seal so air can be compressed and forced into the tank.
Jun 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
MY AIR TANK WILL ONLY HOLD 40 LBS OF AIR WILL NOT GO ANY HIGHER I HAD THE PRESSURE SWITCH TESTED AND ITS GOOD WHEN IT GETS UP TO 40 LBS IT STAYS RUNNING AND WILL NOT SHUT OFF MODEL FP209001 2 GAL...
If the pump is putting out 40 lbs then it is working these things are loud there must be air leaking out some where are you sure that the petcok on the bottom of the tank is closed or the blow out valve is not leaking or mabey I would say the gauge but it dosn;t shut off If the pump is putting air in that tank it eigther compresses or it comes out run your hands all around the mechine when its running there must be a leak
Nov 24, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air pressure goes to 40 lbs motor continues to run and no air pressure gain
Are you sure the gauge is relaible??
If so then a valve in the compressor is allowing leakage.
Jan 03, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What is the torque for head bolts on my ingersoll rand ss3 compressor?
I can't say from their manual, but I've never rebuilt a compressor (and I check every one with the mfg) for which the head bolt torque isn't in the range of 25 ft. lbs. to 40 ft lbs. If you can't find it, torque to 30 or 35 and you've got it knocked.
Nov 25, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
Tighten head bolt # ? torque 2.2l eng ply sundance 1991
  1. For vehicles with A/C and solid mount compressors, install the solid mount compressor bracket as follows:
    1. Position the spacer onto the stud, then install the bracket on the front (2 nut) mounting stud and slide the bracket over the timing belt cover into position.
    2. Loosen the assembly bracket-to-engine fasteners (numbered 1 through 7-refer to the accompanying illustration).
WARNING The bracket fasteners must be tightened in the proper sequence and to the specified torque values.
  1. Tighten the fasteners in the following sequence: 1) bolt 1 to 30 inch lbs. (3.3 Nm), 2) nut 2 and bolt 3 to 40 ft. lbs. (54 Nm), 3) bolts 1, 4 and 5 to 40 ft. lbs. (54 Nm), 4) bolts 6 and 7 to 40 ft. lbs. (54 Nm).
  2. Install the alternator and compressor to the bracket. Tighten the compressor mounting bolts to 40 ft. lbs. (54 Nm).
Nov 23, 2009 | 1991 Plymouth Sundance
Air Tools & Compressors Logo
100 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
