Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Changed my mower belt now my mower will not start. Is there something i might have done so it will not start. it doesn't even try to turn over.
  • Craftsman Master
  • 8,404 Answers
You may have the mower 'engaged'.
Now you know and I know this is not the case ... but the mower has to know it. There are a series of what are called "operator presence" safety switches. You may have bumped one of these switches into the "engage" mode telling the mower there is a 'safety vilolation' - don't start.
Check out the switches and adjust as may be necessary. You may find out where it is by removing the belt and even removing the deck to see if the engine will start. With the deck removed (yea i know it is a lot of work) you will have better access to the area most likely to have the switches. (There is a switch in the seat also ... you must be on the tracor to start unless the parking brake is set (on most mocels)). You coud consult your operators manual for further details on this matter.
Thank you for your interest in FixYa.com
Posted on May 31, 2010
My Wheel Horse mower acted like low on gas so I filled it. Turned on the mower blades and off and on when moving and it seemed like a belt slipped. It ran unevenly, quit running and won't start.
Even if you have slipped or broken the blade belt, that would have nothing at all to do with keeping it from starting UNLESS you are trying to start it with the blades still engaged. Check that.
Jul 02, 2016 | Garden
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
SmengesI have a briggs statton 6.75 series Craftman lawn mower 21" cut ,that I cant start. Recently serviced with spark plug, oil and air filter replacement. Brought it home and it the same problem....
I can only go by what you say was done. If you took mower to repairman then it should run. If you took to a buddy who thought he knew, WELL.
Try this first. The primer button is a round button usually BLACK, CLEAR, or RED. Look around your mower and you will find it at the end of the carburator. Carburator is opposite the muffler on your mower. With new gas in your mower ,press the primer button three or four times. Try to start. With all you have done it should start. If it doesn't start, think back and try to remember if you hit something while mowing, if you did then your problem is your timing. With the hit you sheared your timing key. This key keeps your fuel ,compression, and spark happily together to keep your engine running.
Check the other things first and please get back to me, I will be more than happy to help you further. GOOD LUCK.
Sep 01, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Mower will not start, seems to be ignition problem, engine doesn't even try to fire. checked spark plug and gap, checked ignition switch wire and changed coil pack.
Remember, if all of the safety interlocks aren't "made", the ignition circuit will never "close".
The symptom will be not even trying to turn over.
Gary
Jun 27, 2011 | Garden
I have a Swisher 2460 ZTR. When the dirve belt is attached the starter cannot turn the motor shaft enough to start the machine. I saw an earlier post where you instructed the person to check the bearings...
If the left side pulley is free of any belts, it should move as freely as the right side pulley. You will need to replace the bearings in the left pulley and all should be well.
May 18, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
No forward or backward movement
change your drivebelt
shack
Apr 18, 2009 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
155 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
