Question about Carrier 38CKC036 Air Conditioner
OUR A/C UNIT IS THE LOUDEST ON THE BLOCK. I CAN HEAR IT ALL THE WAY DOWN THE STREET.(LOUD HUMMMING). IS THERE A WAY TO QUIET IT DOWN BY LUBRICATING IT? WHAT TYPE OF OIL DOES IT TAKE AND WHERE DO YOU INSTALL IT? ANY HELP IS APPRECIATED!
  • rrmorris5 May 31, 2010
    THANKS FOR YOUR INFORMATION.WILL TRY YOUR SUGGESTIONS
  • 8,404 Answers
Is it the compressor or is it the housing? Very likely the housing has vibrated loose and is making the racket. Find this out by pressing several places on the housing cabinet. If this does't change anything ... the motor mounts may have failed and require replacement. It may be a combo of the problems.
If it is the housing, you will have to tighten it up any way you can from tightening the screws nuts and bolts to wedging something between the offending parts. I suspect you will find the fan grill is the major cause of the sound you are hearing.
If it is the compressor ... you should get a AC professional to look at your compressor as soon as you can. Post your question in the "Local Repair" section of FixYa.com for fast results.
Thank you for your interest in FixYa.com
Posted on May 31, 2010
  • 1 more comment
    IS THERE A PLACE TO OIL THE FAN OR MOTOR. THANKS FOR YOUR FIRST SUGGESTION
  • A Miller May 31, 2010
    I wouldn't think the motor is making that much noise that it could be quieted down with 3 or 4 drops of oil ... I believe your fan motor is equipped with sealed bearings. The compressor is in a sealed package and is lubricated by the oil that is in with the coolant product.
    If it is naking that much noise from the compressor or the fan and cannot be quited down by the method I suggested ... you need to have your AC service take a look at it before more, serious damage occurs.
    Thank you for the feedback and additional question.
    Good luck with your project ... thanks for the 4 thumbs up ...
What causes an intermittent loud clanging noise. Loudest when the hood is up?
Remove the drive belt and inspect the harmonic balancer for separation.
May 21, 2014 | 2002 Buick LeSabre
HELLO, The Problem I'm having is My Honda EX 800 Generator, The Problem is, it's loud and also has a loud rattle, ANY IDEA'S ????
When it comes to gas generators "quiet" is a relative term, the EX 800 is quiet relative to other gas generators yes, but is not quiet by any means. If you hear a rattle check the panels for a loose sections which you should be able to hand tighten with a screwdriver from either end of the unit.
May 16, 2012 | Honda Electrical Supplies
I have a alpine type r 12 in a seald box and want to know how to adjust my amp to sound right with metal and rock
hard to do because it is a VERY loud sub. turn the frequency down low on the amp so as just to be able to hear the kickdrum and bass line and turn the gain up just loud enough where you can hear it comfortably ( to your taste) at the loudest volume your going to listen to it at. if you do it right itll sound good. if you turn gain up past half or more it might blow your sub so be careful.
Sep 12, 2011 | Hifonics BRZ17001D Car Amp
Was loud, now quiet, never changed any setings.
there are many possibilities here:
-one of the subs came unplugged?
-you blew one of the subs
-your amp is over-heating
-some wire has been fried in your amp
-the RCA outputs on your cd player are going bad.
May 09, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
What is loud sound suppressoion
It is a dynamic range compression feature. Due to the widespread abuse of Dolby and other digital dynamic range features, normal listening levels may be interrupted by VERY LOUD explosions, etc. which may not only wake you up, if you fall asleep in front of the set but can make your neighbors very annoyed. To counteract this, a loud sound suppression feature, sometimes called "Late night listening" is offered to limit the loudest sound you will hear.
Jan 09, 2010 | Sanyo DP42848 LCD TV
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Cant hear very soft even on loud seting
bro it looks like that ur earpiece has gone bad.need to replace it.bfore doing that though do connect an earphone to check that the voice is loud in it - if so then ul hav to spend sum money.ive heard of these problems bfore from xpress muzik phones.
May 04, 2009 | Nokia 5310 Cellular Phone
Alarm not loud enough
I am assuming you have not had this oven for long- anyway just in case, i will tell you that if you depress the minus (-) button (the one you use to deduct minutes off your chosen time setting), you should hear three disctinct beeps", a low, medium and high pitch one. Stop depressing the button as soon as you hear the loudest one and that means it is set on loud!
comprende amigo? Suerte!
Oct 28, 2008 | Rangemaster 110 (Gas) Kitchen Range
Carrier 38CKC036 Air Conditioner Logo
46 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
