Hello, My Plasma TV stop working and after technical support we find that the problem is the ?Board?. I need a new board so that the TV works fine again. Can you pleased help? Here are the details of my Plasma TV set: Model: LG MZ-42PZ14 Serial number: 208KT00684 Panel model: 42SD3 Damaged board reference: 6871QZH020A or 6871QZH020B Board model: ZSUS
  • 8,457 Answers
Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes boards.Search ur board and compare serial numbers and picture to buy.
Posted on May 31, 2010
All HDMI ports not working on Hitachi 42HDS69 Plasma TV. Coax DOES work.
It sounds as if the HDMI portion of the main board is shot. That is likely a separate module that can be replaced without replacing the entire tv, however the cost is a mystery. Contact the manufacturer and they may be able to advise you of a repair center local to you, or you can search online. Being that it's an older Plasma TV, parts may be scarce and pricey. I have had a main board replaced 3 times on a single TV, though it was an LED LCD instead of Plasma, but it was under warranty, and after the 3rd swap, I got a credit towards a replacement tv. Your situation may be a losing proposition unless the board can be cheaply and easily replaced. If you feel comfortable enough with your own technical skills and can use simple tools (screw driver), you may be able to take the cover off the tv, get the model number for the board (may be printed directly on the circuit board), and order the replacement board online. The board will typically have a few ribbon cables and plastic molex connectors plugged into it, that can be carefully unplugged and reconnected to the new board once it is screwed in. There is probably no greater feeling in the world than fixing something like that without paying a costly repair bill. I wish you the best of luck.
Jul 08, 2017 | Hitachi Televison & Video
What can be the problem with a pcb # LJ41-08592A ysus board?
have you been able to obtain a circuit diagram for the TV. because you are looking for needle in a hay stack.
You say that there is no picture , But how far does the power go to .You need to know the correct voltage at points of the TV say if its working correctly. because they only have to be out by 0.1 Volt and the devices will stop or not work correctly. Same goes for the thightristors which alter with the temperature . This is why you have been advised to get a new board.
Jeff
Jun 10, 2014 | RCA 42PA30RQ 42 Class Plasma TV - 1024 x...
Samsung plasma TV cooling fan didn't turn on and the TV overheated. Tried replacing with a new fan, but that fan will not turn on either. TV works just fine with back cover removed and a 12" desk fan...
the is a fuse on the board if you follow the power line on the board back to the main power board you will find it. also test the volts with a meter just make sure you have volts. some of these models also have a thermal switch that then the tv hit a surtan temp the fan kicks in.
Sep 17, 2013 | Hitachi 42 in. Plasma TV
Picture went black but you could still hear the movie
Hi- My PL4260N stopped working after about three years, the audio worked but no video at all. The TV worked fine until one day...no more picture.
I found out that the YSUS and ZSUS boards in the TC fail alot...BUT you can get new or repaired ones off of EBAY...
First check for failed components (burned, loose, bulging, etc.) if nothing obvious is failed then check the fuses on the YSUS, ZSUS, and power supply boards...usually if a board has a blown fuse the board needs to be replaced...get the part number and search it in Google and eBay and you will find options for replace/repair.
Mine had a blown fuse on the YSUS board...I got it fixed for $75 through coppell TV (they are on Ebay)....
Now my TV works fine again!
Good luck.
Dec 19, 2010 | HP PL4260N 42 in. Plasma HDTV
Tv turns itself off immediately after turning it on Plasma tv Model: 50PY3DF
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Sep 14, 2010 | LG 50PY3D Plasma TV
The TV will not Turn On
Hi
Thanks for using FixYa. These kinds of issues in plasmas usually occur after 3-4years as plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | LG 50PC3D 50 in. Plasma Television
My hp plasma tv lost it's picture. Audio works fine. Work are some causes of this?
The T-con board, the board that sit right in the middle of the center LCD panel . That board is dying. try websites like shopjimmy.com, Ebay.com to buy a refurbish T-con board for replacement.
Thanks for using fixya
Aug 20, 2010 | HP PL4260N 42 in. Plasma HDTV
Panasoni tv will not turn on inmidiatelly....takes hours for it to be able to turn it on ...ow can I solve this....?
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged/leaky capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 11, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Samsung plasma cable problem
your digital or anolog board is bad needs replaced can find on ebay if you can get part #
Jan 23, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung PS42P2S 42" plasma Sound problem
I also have that problem with mines but my HiFi has audio inputs and i use that for my audio and it works .
Defo weird
Aug 01, 2008 | Samsung PS42P2S 42 in. Plasma Television
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
