Question about Dell OptiPlex SX270 PC Desktop
SX260 Hard Disk Compatibility &c
My Dell SX260 uses a 40GB Hitachi Travelstar 40GNX series, which is ATA-5 based. It is failing, probably because I did not allow much vent space above the drive although I was careful to mount it per instructions with that side up. I have copied the drive to a 3.5" drive I had on hand. I am minimally familiar with notebook drives and with SX260 quirks, so have several questions.
[1] - I see many ATA-6 drives for sale, but few ATA-5. Is there any reason that I cannot use an ATA-6 drive? Any specific suggestions to look for or avoid?
[2] - Storage size is not too important. I'd probably get 60GB ATA-6 if that will work, prices for 40 and 60 being so close. I would like a better drive if possible, where better means, first, one with greater heat tolerance than the 40GNX 55degC spec. Any suggestions for 60degC and up?
[3] - Better would secondarily mean better performance. Are 7200RPM 2.5inch drives compatible? Other suggestions for better performance - but while maintaining good thermal tolerance.
[4] - The SX260 case offers easy access to the drive but doesn't look notably well designed for cooling. Any suggestions for modding it for cooling. The compartment seems about deep enough for a very thin HD fan...
[5] - I use the SX260 just for websurfing and email most of the time. Sometimes I think about dual booting to full Windows (XPPro) or to some stripped down O/S set up for rapid booting, and supporting just a notepad, email, and web browsing. Then I start to think that for safety I would still need a local firewall, antivirus, antispyware, moreantispyware, etc. - and I lose interest. Any thoughts?
Thanks so much.
  • captainfepa Apr 09, 2008
    Thank you, myob247, for your assistance. (I did expect that ATA-6 should work within the ATA-5 DMA limit of 66 MHz, but I consider all Dell a bit quirky and preferred to hear about SX260 experience specifically before spending my money.) Anyway, I'm still interested in recommendations for (reasonably priced) 2.5 drives with best heat tolerance and/or schemes for improved cooling of the SX260 SFF case.
I have replaced the standard hd in a couple sx260's .One with an 80gb ata-6 and one with a 60gb ata-100. You will have to install an operating system(I used xp) and all of the system drivers.
Posted on Jan 19, 2009
  • 1,342 Answers
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
Hello, quick question: I have a totally broken IBM laptop, and I've removed the hard drive, which is a 40GB Hitachi Travelstar 5400RPM ATA/IDE: Exact model#: HTS541040G9AT00 I'd like to copy the...
Yes! There is such an adapter. Look here for IDE/SATA to USB:
Obviously, you don't have to buy this product or buy from Tiger Direct; this is just an example of the type of product you're looking for.
If you're comfortable working inside your desktop, then you should check out this product which is much cheaper:
Good luck and thanks for using FixYa.
Mar 16, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
I have LatitudeD510 and my disk makes lot of noise. Its on Windows7 and I think the disk is a Hitachi - HTS541040G9AT00
chances are that you simply do not have the resources to run windows 7. These are the basic (recommended minimum), for windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor.
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit).
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit).
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • 1 more GB of RAM & 15 GB more HDD space to run 7 in XP Mode.
These are the typical resources that come with your machine.
  • Processor Pentium M 1.73 GHz
  • Ram Installed Size 512.0 MB
  • Technology DDR2 SDRAM
  • Hard Drive 40.0 GB
  • OS Provided Microsoft Windows XP Professional
It would probably be advisable to go back to XP
Good luck
Jan 07, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Computer has become very very slow. Reformated and reloaded operating system took forevery to reload (2 hours). Is this a hard disk problem
It _could_ be a disk-drive problem -- excessive "retry" operations within the disk-drive, while trying to write data to the disk-drive, or while trying to read from the disk-drive.
Search online for "Hitachi Drive Fitness" testing software, and run it.
If the disk-drive is "out-of-warranty", consider replacing it, before it completely "fails".
Nov 11, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
please suggest us the solutions of locked 40GB above said hard disk and how to unlock it?
Dec 14, 2008 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Backing up the Hard Drive
I take it your hard drive is IDE. Most enclosures only support 3,5" inch harddrives with either SATA or IDE interfaces. A notebook's HDD can have the IDE interface but it's way smaller than the standard.
There is an option however, it isn't necessarily an enclosure. You can look for the A.C. Ryan uDrive. It's a USB device which allows you to connect harddisks or optical drives from three different interfaces without the hassle of building in the drive in an enclosure.
If this is what you need, check this page:
[A.C. Ryan uDrive]
You'll need to connect your harddrive to the 2,5 inch drive connector on the device.
I hope this is what you were looking for.
Let me know if this solved your problem.
Jan 24, 2008 | IBM TravelStar 40GNX 40 GB Hard Drive
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell OptiPlex SX270 PC Desktop Logo
294 people viewed this question
Alun Cox
