Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
What is causing the "shorted on water sensor"?
What is causing the "shorted on water sensor" indicator when we turn on the spa? We have an RP2100 swimming pool & spa heater, model R185 - R405. We opened the respective panels and see that all connections are as they should be.
I have a RayPak 2100 heater and I have the following error:
Water sensor shorted. How do I resolve the problem?
Posted on Jun 03, 2010
Need to replace heat sensor, where is it located on the unit?
there should be 3 heat sensors on the unit. Incoming water to decide if it needs heat, outgoing water, and a sensor on the burner(flame). the in and out sensor should be behind a panel near the inlet and outlet pipes. The burner sensor is more tricky usually near the igniter or below the heat exchanger inside the unit.
Jun 18, 2015 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do you change a senor on raypak r335b
water sensor is mounted to the header of heat exchanger
May 30, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
SNS appears on digital screen
This indicates the the 2 installed temp sensors are having a reading the is more than 2 degrees in difference. It is either a failed sensor, or one of the sensors is not fit snuggly into the header.
To test a sensor, turn your multimeter on OHMS or RESISTANCE and connect probes to each wire. at 80 degrees, the sensor should read 93 OHMS. At 70 degrees it should read 118 OHMS
at 60 degrees it should read 153 OHMS
Sep 05, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Displays HL and has been on for hours but not heating. Help!
HL usually indicates high limit which will shut down the unit. if power is turned off for a min or two it may result the fault. on some units there may be a reset button in the control unit. if it doesent reset it is most likely the hl thermal (temperature) sensor hope this helps
Aug 20, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
309 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
