Question about Olympus FE-230 Digital Camera
Camera won't work
Camera won't turn on, focus is blurred, try to focus it clear, but it went back to blur and when I tried turning it back on the shutter kept making focusing sounds then shuts off
  • Chairbeck May 08, 2008
    When my camera is turn on, it will show blur image in any of the setting. When I tried to zoom it outward it won't but when I tried to zoom inward, it will but will still be blurred. When I tried to zoom it again outward, it will focus in super macro mode and will only focus in that position.
    Is there any way I can overcome the problem? Or shall I see a Technician to repair it? I bought the unit in Singapore last June 2007. It's still within the warranty period. Will try to get in touch with the Technician here if there is no solution yet from you. Thanks and a pleasant day.
  • lol-3 May 19, 2008
    Focus is blurred no matter what I do. Bought the camera in Minneapolis last summer.
Sounds like a problem with the ccd, email me at rmorgan780@excite.com, may be able to repair for you, Bob
Posted on May 03, 2008
I had the SAME problem with mine, and I found out that if you hold down the menu button until it resets--it is completely fine!
Posted on May 28, 2008
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
My camera is showing blurred pictures when taking pictures help
Try reseting all menus to default, then try again to test.
Make sure the lens is clean.
Do the menus appear clear?
Has the camera ever been dropped or had any other damage? This could get the lens out of focus, and would need repair.
Does blurring happen when zooming or when taking a picture of any kind?
Sep 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Webcam blurred
Very often this is a problem with the focus. Check if the webcam has a focus ring in front of it and if so, try turning it to sharpen the image.
Jun 08, 2009 | QPS QSIPBL2 Network Camera
Every picture I take is blurred
Try to reset your camera.
Press Menu.
Go to Set Up.
Go to Reset.
Select Yes.
Press Menu.
Dec 16, 2008 | Samsung Digimax D53 Digital Camera
Pictures are blurred around the edges
Have you tried to change the settings like to scenery or adjusted for lighting that could have an effect. The only time it's blurry for me is when I don't adjust for the picture I am taking. The camera itself focuses so maybe there hasn't been enough time for it to focus. Try those things and if it doesn't work I would take it in to a camera shop maybe it has internal problems.
Sep 27, 2008 | Nikon Coolpix S51c Digital Camera
JVC camcorder with blurred images
It could be an issue with the dioptre adjustment: 1 Set the Power Switch to ?A? or ?M? while pressing down the Lock Button located on the switch. 2 Make sure the LCD monitor is closed and locked. Pull out the viewfinder fully and adjust it manually for best viewability. So slide the rubber eyecup toward you. 3 Turn the Dioptre Adjustment Control until the indications in the viewfinder are clearly focused. The control is a litttle knob on the sied of eye-piece. While looking through the viewfinder, turn the knob until it is focused. Hope this helps. NewMediaMan
Jun 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Olympus FE-230 Digital Camera Logo
346 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
