Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
I have a Roper Top freezer RT18ECRFW01 how cold should the refridgerator part be. How long does it take to freeze icecube trays normally
SOURCE: Roper refrigerator leaking from pipe
Thanks for your help! I have a tech coming tomorrow so I'll let you know what the problem was.
Posted on Sep 25, 2007
  • 27 Answers
SOURCE: leak
drain line is clogged. when the frig defrosts the water drains through a tube down to the bottom of the frig near the compressor where it evaporates away. look on the back of the unit to see if the tube runs down the back. follow it to the end. you need to blow backwards through that tube. let me know if this helps.
Posted on Nov 01, 2007
localwonder
  • 6784 Answers
SOURCE: roper refrigerator freezer not freezing and bottom not cold
This is a compressor issue. Its probably done.
Posted on Feb 14, 2009
peyton32034
  • 410 Answers
SOURCE: I have a roper refrigerator and the top is
Sorry it took me so long to get back to ya!
It sounds as if the return air ducts have frozen over.  the square holes your talking about are returns. so lets follow these instructions for cleaning the drain and while your at it you can def the return air at the same time.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
After doing this let me know how it turns out. Your drain may not be plugged but these instructions will get you to the returns and cleaning the drain will save you problems later on as well. Peyton
Posted on Mar 15, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Posted on Apr 23, 2009
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
NEW FAN WILL NOT QUIT RUNNING
Hello.
How long did you wait after installing the fan? It takes 24 hours for the unit to recuperate.
If the fan hasn't been working for a long time, you may have not noticed it was running a lot, but with the new fan you can hear it. Let me know if you don't think this is the case and I can guide you through some other options.
Dec 03, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
49 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
