Attempting to repair older Pioneer power amp. model A77X. Faulty ic drives part #pa0016, in conjunction with both transformers need replacements. if replacement icdrives are available, please quote price and approx, delivery. Thanks.
  • 4,234 Answers
If the output pac (PA0016) as well as the transformers need to be replaced, you are going to have a hard time finding them for one and none of them are cheap. What is the problem with the piece that leads you to believe that you need all of these parts?
Dan
Posted on Apr 08, 2008
HELP PIONEER RX-570 NO SOUND
Check the connected speaker/s first. If found OK, the power amplifier section circuit inside the Amp: is faulty. Contact any service technician to get it repaired. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 12, 2015 | Pioneer Audio Players & Recorders
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
DV-585K (PIONEER), My player is not turning on. I've already check the cord, fuse and the switch and they are all good. What else could I check or is there any parts that needs to be replace if problem is...
The most common caused why your unit didn't power up was because of faulty power supply board. Since you've already checked the AC line, the fault now is quite technical if you haven't an experienced in electronics. The board must check the faulty parts like the fusible resistor in line with the shorted voltage regulator IC/transistor (mounted in heat sink), dried electrolytic filter capacitor, open/shorted chopper transformer, shorted diode. You must know how to test this parts to pinpoint where the fault came from. If you can't troubleshoot the board yourself, you may replaced it by inquiring to your local pioneer service center for the power supply board's availability.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Apr 24, 2011 | Televison & Video
CDJ 200 meant for US mains supply plugged directly into UK mains supply, now don't work. Replaced external fuse but still don't work..anything else i can try before i bin it?
Dont bin it!!!
If you are really lucky it may have just blown an internal fuse or if your not so lucky it may have killed the mains transformer which is still worth repairing.
If the transformer is faulty and was replaced with one sourced from Pioneer GB then no external 240V to 110V transformer would be needed - you would be able to plug it straight into a UK mains supply.
Jul 20, 2010 | Pioneer CDJ-200 CD Player
How to repair Vizio VP 322 power supply
Power Supply repair is NOT easy, but here goes. First Without Power do as"Dry" Multimeter Ohms, check of ALL discrete components looking for "Shorts" Check, Diodes, Caps, Resistors. Coils etc.., Check all Transistors, B.C.E. with your meter set on "Diode test" look for "Bad" junctions. Then you check to see if you have power to and on the "other side" of the Bridge Rectifiers/Diodes. if not, replace that. if yes, proceed. Check for the correct Voltages around the Controller Chip. and Check the output of the Chopper Transformer, Check to see if the Waveform around the Controller IC is right. Check ALL voltages are correct & within range.. Now during this you should have found the faulty Bit(s). Replace as necessary. BE CAREFUL. I always work on ANYTHING connected to mains through an Isolation Transformer.
Feb 03, 2010 | Vizio L37 Television
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
Pioneer car stereo output Ic's
In most cases the problem is the electronic volume IC, ref # IC151 and part number PLM003AM (in the DEH-1600). It is a different part number and ref # in other models.
It is not always this part that causes the failure, sometimes it can be the muting transistor, a voltage regulator or even the micro on more rare occasions. It will require some troubleshooting to figure out exactly what part it needs. You will need to have an O-scope to trace down the audio signal and follow it from one pin to another. You also need a multimeter to check a few voltages in the radio. All of this must be done on a test bench with the radio powered on with a power supply. If you do not have these tools, you will not be able to figure it out for certain, you would only be taking a stab in the dark. That can get rather frustrating and even expensive buying parts that do not fix the problem.
The electronic volume IC is a flat pack surface mounted component and requires the very best soldering skills to be able to replace. It is very easy to do damage to the circuit board that can not be repaired if it is not done perfectly. If you have not replaced these type of components before, you should not even attempt this repair.
If you would like the service manual I can sell you the PDF format of it for $10. I also have the service manuals for most Pioneer products as well as Kenwoods, JVC, Panasonic, Denon, Marantz, Clarion, and more. Let me know if you would like to get it. The service manual is very helpful in repairing electronics. It contains the schematics and parts list which is vital to make sure you get the right parts and to be able to trace down any signals and to know what parts are doing wha, and to figuring out if the voltages are correct.
I hope this helps,
Dave
I hope this helps
Nov 17, 2008 | Pioneer DEH-1600 CD Player
No sound from a pioneer deh p5200
due to being an older model radio the output (ic) which is behind the rear of the radio is probably unsoldered or faulty the part number is pal 005a or pal 007a which is replaceable with a tda 7386 which is the same part but cheaper.
Aug 31, 2008 | Pioneer DEH-P5200 CD Player
I have a older model
You will need to replace both convergence ICs. This is a simple common repair for all projection TVs. If you would like I can post a link where you can order your ICs and they provide step by step instructions on how to remove the old and install the new ones.
Mar 28, 2008 | Pioneer PRO-119 60" Rear Projection...
Tv wont turn on
Hi There!
Sounds to me like a frame collapse. Not familiar with this model though. My guess would be that the frame IC is faulty. This could be from over voltage from the supply side, Line Transformer which is arcing or just a general vertical amp failure. I would try replacing the caps in the power supply first and then the IC. Cheap enough to try. If all else fails refer to a repair technician. The Line Stage may be at fault. Good Luck, JUS004
Feb 26, 2008 | Samsung TXP2675WH 26" TV
176 people viewed this question
 Grubhead
Grubhead
