Question about Dwin TransVision 3 Plus Multimedia Projector
My DWIN Transvision 3 projector works fine for 10-15 minutes and then shuts off. I suspect it may be overheating. Any suggestions?
    President:
  • 4,070 Answers
Hi! For sure its an overheating problem. Check the fan if working properly or blowing strong. If not, then the fan may cause overheat for its weak. You will need to replace it. Hope this helps and have a good one!
Posted on May 31, 2010
I have a transvision 3 that starts up and runs fine. at some undetermined point the picture will flash back and forth from snow to the clear picture????
prestopete here...no kidding..I have the same problem...Can't find any cables. I do have a source for bulbs if you need.
Mar 25, 2012 | Dwin TransVision 3 Plus Multimedia...
I have a Dwin TransVision 4 that is not working. It started out with us being able to watch a movie for about an hour and the bulb shutting down. I finally ordered a bulb from Dwin (at 458.00!!) and...
honestly it sounds as if a capasitor is overheating and once it overheats the machine is shutting off.... I myself would be able to look at it and see if this was correct or not. i am not sure how familliar you are with these types of things, probably best to take it in and tell them exactly what is wrong...
Feb 26, 2011 | Dwin TransVision 3 Plus Multimedia...
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
Replacment of bulb on dwin transvision 3 plus ceiling mounted
It is fairly simple. Take the unit down as you need to get to the underside. There you will see the retaining screws that hold the cover on. Remove these and open the unit. Inside you will see the bulb and mounting bracket. Off hand I don't remember exactly how it is held in place but there are a number of screws and a lead to disconnect to remove it.
Mar 09, 2009 | Dwin TransVision 3 Plus Multimedia...
Picture becomes unstable after turning it on (lack of color,
The problem is with overheating!. after a few years the fans accumulate dust and "stuff" and don't work as well. Get a can of compressed air and blow out all the ports and fans. I take the cover off and with everything cool, I blow out all the internal fans also. The 3 big fans on the back are easy to remove and clean and get spinning again. Usually this fixes the issue for several months but eventually, professional cleaning may be needed at DWIN.
Dec 23, 2008 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
113 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
