Question about Epson R1900 Printer
The paper/garbage can is on - not flashing and the printer power light is flashing.
  • egolden117 May 31, 2010
    Sorry I clicked off so fast. I was afraid you'd say that!!
    Thanks for your effort!
  • Epson Master
  • 4,737 Answers
First check your cartridges, if possible replace them. You'll see the what exactly the root of the problem is. This is the main cause with this kind of problem, almost 90% is solved after replacing the cartridges. Even after replacing the cartridge, you see no solution, remove the cartridges, unplug the cables including the usb cable. Open the back door, check for paper pieces or anything which is present, if so remove them and clean it. Clean the cartridge interfaces and the corresponding printer interfaces as well. Plug in the power cable, usb and install the cartridges, now power on the printer, Power on the printer without the cartridges, and leave it for few minutes. Switch off and again while you press the power switch several times. This will fix your problem. If still have problem even after this, do let me know so that i can assist you further. Good luck. Thanks for using FixYa.
Posted on May 31, 2010
  • 1 more comment
    Just want to be clear that the printer is new and so are the cartridges. Do you still recommend your solutions (please repeat - I lost it by asking to make a reply).
    Thanks.
    Ellen
  • Lebanon Raingam
    Lebanon Raingam May 31, 2010
    Oh, sorry, if it's new then there's must be internal or firmware problem, you better get another replacement. I hope it has warranty with it. I can't help you further if it's a new unit. Wish you good luck.
  • Lebanon Raingam
    Thanks, actually you should have asked us on the community with full detail about your problem. Sometimes questions are very confusing, we need to assume as well. Anyway good luck, your only choice it return the Printer to the dealer for a new replacement. Thanks again for visiting FixYa.
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
HP 1022 Printer, OS X 4, printer jam
Unplug it for a minute or so. Make sure all the paper is out. Turn it back on. Macs usually have their own drivers. Did it come with a disk. Please rate me
Jun 18, 2009 | HP LaserJet 1022 Printer
Error code 92
the paper size selected on your pc does not match the paper size in your copier.check to see if the sizes match.
May 11, 2009 | Gestetner Office Equipment & Supplies
Hp 7260 will not pick up paper
Yea, I have the same problem. The only answer I can think of is to never buy another HP printer. I've had nothing but trouble with this piece of garbage!
May 13, 2008 | HP PhotoSmart 7260 InkJet Printer
Printer won't print
I've had this 6110xi all-in-one for a few years now. Everytime I have the "no-printing" issue I need to unplug the printer, and leave it unplugged overnight. The problem magically goes away in the morning.
I've installed the printer on a separate computer while it was having a "no-printing" episode and still couldn't print there either. So it sounds like there's something funky with the printer internal cache requiring a long power-down.
Dec 03, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
