Question about Coldtech P2SRR-16S Commercial Refrigerator
Evaporator coil and vaccuum problem with the P2SRR-16S.
Another company removed evaporator coil and broke suction line off. They said it had a leak. I repaired the suction line, reinstalled the evaporator coil, and sautered the cap tube back in. Now every time I start up the system it pulls into a vaccuum. Charge is 11 1/4 ounces. I pulled evaporator 3 times and flushed. System is still pulling a vaccuum. Is there a regulator or metering device that is supposed to be on the coil, other than just a cap tube?
Motor runs not chilling. Contacted Avanti, they said I need to use a local service person but none are available.
You said the compressor is running? Right? Check for the temperature of the suction line to compressor (line going to compressor from the evaporator coil) - it should be cold. The other line going to evaporator should be nice and hot.
If suction line is not cold, then the unit may have a gas leak and needs to be regassed. However, you need to first locate the leak, repair it, evacuate the system to make sure the fix is good and then refill with appropriate refrigerant. U will need to get a shrader valve to tap into the suction line, a leak detector, leak repair tools, vacuum pump, and refrigerant with manifold.
Oct 23, 2015 | Avanti WC681BG Wine Cooler
How do i replace ac evaporator on 1997 gmc sierra
This is not something that is easy, cheap or something a novice should do, you need to have special tools and training ,you have to change the receiver dryer and flush the system. That is why it costs thousands to have it done at a shop.
Feb 14, 2015 | 1997 GMC Sierra
My goodman unit is freezing up. It is frozen from the line running out of my house than if u look down into unit, the freeze continues inside
Hello, the suction line will freeze either due to low airflow such as dirty air filter, blower wheel, evaporator coil or a weak blower motor. Also, a low refrigerant charge can cause the suction line to freeze up.
Jul 16, 2012 | Goodman Heating & Cooling
Suction line and evaporator coil freezing up
Hello, a air conditioning unit will freeze from lack of airflow or low refrigerant charge. Check filters, make sure blower wheel is clean and running at full speed and that evaporator coil is clean. If that checks out good then you will need a technician to come out and attach guages to the unit to check the operatimg preesures, fimd the leak, amd recharge with refrigerant. Many times the ac will leak at the schreader valves.
Jul 12, 2012 | Carrier Heating & Cooling
I have had a repairman look at this refrigerator and he claims there is a slow leak. Can't a new freon line be installed?
Usually it takes too much labor to fix that line, Kitchenaid built in refrigerators have capillary tube which licks at the back by suction line tube. Refrigerator will need ti be moved out from cabinet in most cases. Tech would want to give You a warranty, so they usually would replace the whole sealed system for big money, but most likely it last 10-15 years. If They will fix one pipe, next year You might call him back, leak might be in different pipe, but it will be the same expensive (due to labor). Check my video out. A Year ago found leak at evaporator, explained to customer better to do the whole system, but he wanted only evaporator replaced since its so obvious. Now we will replace the whole system, Evap is ok, heater too, but now, capillary tube + suction line + drain pan heater loop(freon pipe). If You watch video thru till the end, you will see where heater on old evaporator touching evaporator coil in multiple bents.
Nov 06, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kenmore AC, no cold air
If the evaporator tube is iced up entering the coil and cool to warm leaving the evaporator, that would indicate low on refrigerant or a restriction. If it is iced up entering and leaving the evaporator, then, it could be low on refrigerant,blower not running at proper speed, dirty evaporator coil or filter.
You need to check the suction and head pressure and temperature to determine problem for sure.
Jun 07, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
Why suction line would ice back
Good day,
Unusual question.
Lots of reasons. You didn't say if it was cooling or cycling off and on.
1. Evaporator fan motor in freezer compartment not running. Doesn't allow the refrigerant to boil off and returns as a liquid.
2. Evaporator coil badly frosted allowing no air flow thru it. Same as #1
3. Runs constantly (days). no demand on system, and once again will not boil off before leaving evaporator.
4. Overcharged. Floods back excess charge.
5. Heat exchanger came apart. The capillary tube is soldered to the suction line to transfer heat from the cap tube to the suction line. Necessary on a refrigerator. Common problem.
Hope this helps
Thanks for using fixYa
Jan 21, 2010 | KitchenAid Superba Architect KSCS25INSS...
Reason for inverted suction line above the evaporator
To keep the freon from flowing back into the compressor, flooding the coil and washing the oil off the rings in the compressor.
Please rate solution if helpful. Thanks
Aug 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
This is ''pops'' moore again!trying to save a $ You helped me before on the firing order.went to a/c guy.he tested system,said evaporator was bad and needed to be changed.his est.was my first born and a...
I assume he used a leak tester and found a leak in the evap which is inside the plenum housing. Need to remove the plenum to get access to the evap. big job. If you are technical, you could remove the plenum assembly and let him replace the evap & then let you out the plenum back in. Then take back to have him evacuate and recharge system.
SECTION 412-03: Air Conditioning 1999 Town Car Workshop Manual
REMOVAL AND INSTALLATION Evaporator Core Removal and Installation
NOTE: The evaporator core is not separately serviceable. It is serviced only with the evaporator core housing assembly.
NOTE: Installing a new suction accumulator is not required when repairing the refrigerant system except when there is physical evidence of system contamination from a failed A/C compressor or damage to the suction accumulator.
NOTE: If an evaporator core leak is suspected, the evaporator core must be leak tested before it is removed from the vehicle. For additional information, refer to Section 412-00 .
  1. Remove the evaporator core housing. For additional information, refer to Section 412-02 .
  1. Transfer the components from the old evaporator core housing to the new evaporator core housing
  1. Install the evaporator core housing. For additional
  2. information, refer to Section 412-02
Evaporator Core Housing Removal
  1. Disconnect the battery ground cable (14301).
  1. Recover the refrigerant. For additional information, refer to Section 412-00 .
  1. Drain the radiator. For additional information, refer to Section 303-03 .
  1. Remove the screws and the RH cowl vent screen.
  1. Disconnect the vacuum hoses and the wire harness connector from the evaporative emission canister purge valve (EVAP canister purge valve) (9C915).
  1. Remove the nuts and remove the evaporative emission canister purge valve.
  1. Remove the heater hoses from the heater core.
  1. Remove the screw and reposition the windshield washer fluid reservoir.
  1. Disengage the four wire harness retainers from the top of the RH fender apron.
  1. Remove the RH front wheel and tire.
  1. Remove the screws from the RH fender apron and remove the fender apron.
  1. Disconnect the wire harness connector from the A/C cycling switch (19E561).
  1. Disconnect the wire harness connector from the blower motor (18527).
  1. Disengage the wire harness connector from the retainer.
  1. Disconnect the evaporator to compressor suction line from the suction accumulator/drier (19C836). For spring lock couplings disconnect and connect general procedure, refer to Section 412-00 .
  1. sxg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent damage to the fitting and the tube, use a backup wrench when removing the suction accumulator/drier.
    Disconnect the suction accumulator/drier from the A/C evaporator core.
  1. Remove the clamp screw retaining the A/C accumulator mounting bracket to the A/C evaporator core housing and remove the suction accumulator/drier.
  1. Disconnect the condenser to evaporator tube from the A/C evaporator core (19860). For spring lock couplings disconnect and connect general procedure, refer to Section 412-00 .
  1. Remove the RH instrument panel insulator.
    • Remove the pushpins.
    • Disengage the courtesy lamp holder.
    • Disconnect the power point wire harness connector and remove the RH instrument panel insulator.
  1. Remove the in-car temperature sensor hose and elbow from the evaporator housing.
  1. Remove the nuts at the top of the evaporator housing.
  1. Remove the nuts at the bottom of the evaporator housing.
  1. Remove the screw and nut near the blower motor.
  1. Remove the screws.
  1. Separate the housing and remove the blower motor and A/C evaporator core.
  1. Disconnect the wire harness connector.
  1. Remove the evaporator core cover.
Apr 06, 2009 | 1999 Lincoln Town Car
Evaporator
The following is a general removal procedure of A/C evaporator core. The evaporator is removed differently from different vehicles.
For example, a 1994 Ford Taurus/Mercury Sable instructs you to, "Using a hot knife, cut the top of the air conditioning evaporator housing between the raised outline."
Use a hacksaw or a hot knife to cut the case. Reprinted with the permission of Ford Motor Company.
But a 1993 Ford Probe manual says to simply remove the blower motor and assembly screws before separating the case halves and removing the evaporator.
The following procedure assumes that access to the evaporator has been determined.
  • Recover the refrigerant.
  • Drain the radiator if the heater hose(s) has to be removed to gain access.
  • Remove the heater hose(s), if necessary.
  • Remove any wiring harness, heat shields, brackets, covers, and braces that may restrict access to the evaporator core.
  • Remove the liquid line at the thermostatic expansion valve (TXV) or fixed orifice tube (FOT).
  • Remove the suction line at the evaporator or accumulator outlet.
  • Gain access to the evaporator core as outlined in the service manual.
  • Lift the evaporator from the vehicle.
  • Drain the oil from the evaporator into a calibrated cup.
  • For replacement, reverse the preceding procedure. First, replace the oil with the same amount and type you previously drained.
Jan 10, 2009 | 1984 BMW 7 Series
Coldtech P2SRR-16S Commercial Refrigerator Logo
59 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
billconfused
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
