Question about Insignia IS-LCDTV32 32 in. Television
Tv shuts off after a few seconds
Tv turns off with a soft "pop" sound...attempts to turn tv back on yield same result.
  • Insignia Master
  • 19,396 Answers
Hi.
The problem is likely the PSU. The pop sound is an internal component that is frying (typically a blown capacitor on PSU).
Sometimes it is possible to spot the problem at a glance, as you will see a burnt resistor or a capacitor that is bulged or leaking.
Do not keep turning on the TV and disconnect power, further attempt to turn on the TV may result in further damage to the internal components.
If you need to contact a technician, ring LG at the number listed on the owners manual.
Parts available here:Insignia TV Parts | ShopJimmy
Posted on May 31, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Tv won't turn on
I think its a defective convergence chip/circuit and need a tech to replace it. It could cost about $300 or so.
Nov 04, 2007 | JVC AV-56P575 56" Rear Projection...
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
Hello..my ps3 (slim) console cant play the disc game because after i instert the disc few seconds later there's a sound (like when the disc start to eject) but the disc still inside and the icon for game...
Step 1: Does another game disc work?
Step 2: If so then the problem lies within that disc. If another game disc does not work check all your discs for scratches.
Step 3: if your discs are all Dirty/Scratched try cleaning them with a soft cloth or disc cleaner. Step 4: If none of these yield results try cleaning out the disc sensor inside the ps3.
Step 5: this can be done with a compressed dust cleaner (spray can) or a very SOFT brush. You do not want to damage the ps3. Step 6: This should yield results. If not then there is a hardware malfunction.
May 05, 2011 | Sony Playstation 3 (PS3) Console
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
The TV shut off, made a popping sound. The
Power board short and bad capacitor blown, capacitors usually pop because of shorted or open rectifiers and linear devices that warp inside. This happens due to excessive heat exposure from the current draw. Bad diodes and FET's are usually the root cause as to why capacitors bulge then eventually pop. This means the the x-y sustain boards are not getting their supply voltage resulting a no picture....
The red light flashes an error code for a technician to read, the tv is in protection mode to prevent further damage. Get it serviced at your local repair center or take it back if its under warranty.....
Nov 04, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
