Question about Refrigerators
Our amana fridge model # BH2055W, with a botom freezer will not maintain the temperature.A repairman put in more fluid, but that did not solve the problem. It will not get cold enough and does not maintain an even temperature. we are not sure whether it is the temperature contro; or if it is defrosting too often, how can we tell?
    Novelist:
  • 184 Answers
CHECK THE FREEZER TEMP FOR ZERO DEGREES. PUT A THERMOMETER IN THE FREEZER THAT WILL MEASURE DOWN TO ZERO DEGREES. LET IT SET OVER NIGHT BEFORE CHECKING. IF THE TEMP IN THE FREEZER IS ZERO OR LOWER, THE SEALED SYSTEM IS O.K. IT IS AN AIR FLOW PROBLEM. ON SOME MODELS, THE AIR TO THE FRESH FOOD COMPARTMENT IS CONTROLLED BY AN ELECTRIC, MOTORIZED AIR DAMPER. IT COULD BE DEFECTIVE, STAYING CLOSED WHEN THE CONTROL CALLS FOR MORE COLD AIR. IF YOUR REFRIGERATOR HAS A DIGITAL CONTROL, THERE IS A SENSOR IN EACH COMPARTMENT TO TELL THE ELECTRONIC CONTROL WHAT THE TEMP IS. THE SENSOR (THERMISTOR) COULD BE BREAKING DOWN, GIVING A FALSE READING. THIS WOULD ACCOUNT FOR THE TEMP VARIATIONS.
IF THE FREEZER IS ALSO WARM, THERE COULD BE A RESTRICTION IN THE SEALED SYSTEM. THERE COULD ALSO BE A PROBLEM WITH THE RELAY ON THE COMPRESSOR, NOT ALLOWING THE COMPRESSOR TO START UP WHEN IT IS NEEDED.
BE SURE THE CONDENSER FAN MOTOR IS RUNNING WITH THE COMPRESSOR AND THE CONDENSER COILS ARE NOT PLUGGED WITH DUST, DIRT OR FOREIGN OBJECTS.
Posted on Apr 08, 2008
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
The freezer maintains the temperature, but the refrigirator shows 47 degrees irrespective of the setting.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 29, 2010 | Amana Refrigerators
AMANA FRIDGE ARB190RCW FREEZER AT THE BOTOM. FRIDGE IS RUNNING BUT NOT COOLING. FREEZER BACK WALL FULL OF FROST
Switch off unit for 12 hours and do a proper defrost. once all ice is gone, switch back on and take note if evaporator fan is working.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana BH2055W
Well, first check your compressor current ( you can check current draws by using clamp ampere). Compare the reading with your owner manual. If they are quite lot difference : your compressor is dead or relay is not work or your cable is loosen due to your previous activity.
Jun 09, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Refrigerators Logo
241 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
