Question about Garden
How to put oil in and what type - Garden
  • 177 Answers
What ,where when, what
Posted on Jun 07, 2010
What type of oil do I put in?
Hi Shelly, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
http://bpretail.bp.nl/australie/2_stroke_brochure.pdf
Mar 30, 2016 | Garden
Chevy oil filter stuck on
try a different type of oil filter wrench, the type that fits on the top of the oil filter, like a wrench that fits on a nut. Be sure the filter is really clean too, any oil on it can make the wrench slip. When you put it back on put a but of oil around the seal so it doesn't get stuck again.
Jul 31, 2013 | 2007 Toyota Sienna
I'm about to change my oil for my on my 1981 suzuki gs650gt and I need to know what type of oil to put in and how much. And what type and how much to put in the drive shaft.
remove the lower plastic and the filter should be behind the exhaust. but before you do that the oil type will be shown on the back of the tank.
Apr 07, 2011 | Suzuki GS 650 GT Motorcycles
Cannt get the oil filter to budge
USE OIL FILTER WRENCH USE THE SOCKET TYPE OIL FILTER WRENCH WITH 3/8 EXTENSION AND RATCHETT. YOU HAVE TO LOOSEN OIL FILTER COUNTERCLOCKWISE TRYING LOOSEN OIL FILTER WITH HANDS IMPOSSIBLE BECAUSE FILTER HEAT SEALS AFTER YOU PUT IT ON.
Oct 25, 2010 | Isuzu Trooper Cars & Trucks
Motor oil type
The owner's manual should tell you what the recommended oil should be. Unless they totally screwed up on your oil viscosity, I don't think it's should be too noticeable. Perhaps they did not put the same oil filter, and put in a cheap filter too?
Jun 02, 2010 | 1992 Dodge Dakota
I do not know what type of transmission oil to put in my 1994 suzuki RM 250. I just got it and it would help if i knew how much to put in to. Can you Help me?
you can use the expensive oil such as silkolene light gear oil or you can use 10w40 semi synthetic car oil. we have used this for 15 years of racing. never had a problem with it. never even had to change a clutch.hope this helps.
Feb 19, 2010 | 2005 Suzuki RM 250
WHAT TYPE OIL USE A4 2,5 TDI
depends on the service type you are doing, oil with either VAG code 505 , 507
normal service is a minimum part syn, 5w40 fixed service fully syn, 0w40
Dec 22, 2009 | 1998 Audi A4
Can i drain the transmission fluid on a 05 suzuki forenza my self?
yes. HOWEVER, whe you refill it. make sure that you put in the correct type of oil. refer to your owner manual prior to putting in any old automatice trranny fluid as some tranny's require a sopecial type of oil, put in the wrong one and you fry your transmission. If its a standard, put in the correct weight of gear oil. Not trying to scare you, but i want to make sure that your REFER TO YOUR OWNERS MANUAL for the correct type of oil to put in after you drain it.
good luck.
Sep 27, 2009 | 2005 Suzuki Forenza
Oil cange
What is the best type oil to put in my husbandsYamaha 1900cc Roasdline? I put 10w-30 in it, will that hurt it any or will that be okay?
Sep 16, 2009 | Motorcycles
Do not know what type oil to put in engine, oil change?
SAE 5W-30 (Preferred)
7.1 Liters (7.5 Quarts)
May 27, 2009 | 1998 Cadillac DeVille
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
